- Thank you received: 1
No compression in #2 Cylinder
- monroeraustin
Motor Head wrote: Be aware that if you by another head, to get the matching bearing caps. They are machined to the head. Watch out for the guys selling heads without bearing caps.
Your head looks repairable.
Could you elaborate more on matching bearing caps? What is that?
- Thank you received: 2829
- OldSchoolZ
- Thank you received: 33
Remember, don't work on your bike so much you never ride it.
- monroeraustin
Thanks Ed. Ill keep that in mind...650ed wrote: The caps that hold down the camshafts. During the manufacturing process they are bolted to the head and then the holes that the cams rest in are bored. Each cap is numbered, so when you install the cams it's important to match the cap with the correct position on the head. If you buy a head without the original caps the holes may be close, but they won't be precise. Ed
