- Thank you received: 1
No compression in #2 Cylinder
- monroeraustin
Attachment Ringplacement.jpg not found
I had the top and second ring backwards. On the OEM rings only the second ring is marked "N" the top ring is not. This would be the first mistake I made.
Attachment IMG_0123.JPG not found
Secondly I broke a bolt in the head on the number one camshaft section.
Attachment IMG_0122.JPG not found
Attachment 007.JPG not found
Boy this is a bad day for me and the KZ.. You live and learn... Valves are ok.. I know 85 PSI is low for compression.. I guess having them installed backwards was probably one of the contributing factors.. I will also look at the pistons and see if they are worn and need replacement..
- lemo32
- The Price of Cool aint cheap
- Thank you received: 2
rings on a newly rebuilt motor may have not seated good also, and valve adjustment is also critical, the most important thing is your learning, and that sick feeling you get in your stomach when you screwed something up, will go away when you get that thing fired up. So read, learn and dont give up, man always has power over machine, it gets frustrating, but is very rewarding.
1979 kz 1000 06 katana 750
- Thank you received: 2829
- Motor Head
- Thank you received: 391
- 4TheKZ1000
- Visitor
- Thank you received: 2098
Such things as doing a leak-down test before tear-down usually contributes to a better diagnosis after tear-down.monroeraustin wrote: ...You live and learn....
In the case at hand, a leak-down test would likely have indicated exactly which valve in #2 cylinder was failing to seal when supposedly fully closed. Or whether compression was being lost past the piston/rings into the crankcase.
- sflaz1
Bought my 1973 Z1 in late 1978. Turbo charged 1982.
- monroeraustin
sflaz1 wrote: You might want to call Paul Gast (Fast by Gast). He could probably salvage the head. Might be cheaper than buying a new one.
I am definatly intrested in saving some cash.. Been looking on Ebay at heads and found a few below $60 bucks.. not including shipping.. so If he can do it cheaper than that Its worth a try.. How do I get in contact with him?
- sflaz1
- 4TheKZ1000
- Visitor
Good luck with that...most heads on ebay can be junk or are in need of work...So $60 get head and put it on and go ....not likley??? more like hella no.
- monroeraustin
Were talking about a 30 year old part. I don't know of a part 30 years old you can buy in excellent condition. So its understood it may need reconditioning.4TheKZ1000 wrote:
I am defiantly interested in saving some cash.. Been looking on Ebay at heads and found a few below $60 bucks.. not including shipping.. so If he can do it cheaper than that Its worth a try.. How do I get in contact with him?
I understand the risks of buying used products especially 30 year old motorcycle parts. I just broke a bolt on my existing head and now I am seeking a replacement. I am still trying to see if its fixable so to salvage it. Otherwise I will be buying a used head and having it evaluated by a certified machine shop. I am rebuilding this KZ750 so I expect it to last after this investment..
- Motor Head
Your head looks repairable.
