- Thank you received: 133
Too much oil?
- Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
- 4TheKZ1000
- Visitor
- ramtough_63
4TheKZ1000 wrote: that had to suck....how bad did you get burned?
Luckily I didnt get burned beyond son of a b@#%* Thats HOT" did riun my new jeans though
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
and various enduros dirtbikes minibikes...
- Topper
I can see the oil in the sight glass now. It's not filled all the way to the top. I'll make a final decision in the morning, but I think I'm going to ride.
1979 KZ750 Twin
- trianglelaguna
- Thank you received: 235
but watch that it does not spit out the extra cup or so and coat the rear while riding,give you a nice scare the first time you turn, if it is going to burp some out the crank case breather it should do it in the first ten minutes...if it does not it may later after a good highway stint (mile or three at steady speed 65-70) at speed...does the oil filter on that bike have its own little drain bolt...the oil filter will drain a cup or less and stop on some models....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- KZJOE900
- Admin
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- pete greek1
- Thank you received: 185
- pete greek1
- bountyhunter
- Thank you received: 337
Topper wrote: Not that easy in the dark, on a gravel driveway with no replacement oil and nearest store 45 minutes away.
MFolks reply was enough to encourage me to try a little harder at getting a sight glass reading. I stood beside the bike and leaned it as far over to the right as I could. Jostled it a bit and when I put it back on the center stand suddenly I can see oil in the sight glass.
It's near, but not at the top mark next to the window. I ran it a bit, watched the oil drain out of the window, turned it off and watched it fill back up to the same spot. I now feel like I might be slightly over full, but not dangerously so.
What do you all think?
I also ride a 79 B4: NEVER dump in half a quart, wait ten minutes, then add more. On mine, you have to run the engine to get the oil going and then shut it off and let it drain down at least 1/2 hour before reading.. I have no idea why dumping it in doesn't read right (at least not without running it) but mine does that too.
If you thnk your engine is overfull:
get a CLEAN drain pan and thoroughly drain the oil (not fileter). Pour back in 4 quarts and you should be about dead on. It takes about 4.5 quarts with full drain and filter change.
- bountyhunter
Topper wrote: Christ on a cracker! Ok I guess I'm going into the gravel in the dark. I have a little oil left. I'm hoping I can drain a bit out the drain plug and then just top off if I drain too much.
On the B4, that's a mistake to "top off" and think you will get a proper reading. The oil fill is right over the clutch basket. I think you have to run it for several minutes after topping, then shut off an wait 30 minutes to get a proper reading. I've been bit by this before.
- bountyhunter
17 mm box end wrench, use a small hammer to tap it to break it. make sure you're going clockwise viewed from the top.Topper wrote: In the dark in the gravel I couldn't break the dam oil lug free. Almost pulled the bike over on me and decided it's too late and I don't want to rush.
- Topper
KZJOE900 wrote: Are you checking this on while the bike is on the center stand Topper? If I remember right, I get a totally different reading if I measure on the center stand as opposed to off the center stand.
Yes, it's on the center stand. I can't get an accuarte read without help otherwise.
Gonna try the oil drain plug one more time this morning before I go. But if I can't get it within a couple minutes I'm going to go ahead and ride. I suspect I'm about half a quart (maybe 3/4) over full. I don't think that's going to lead to catastrophe.
1979 KZ750 Twin
