- Thank you received: 6
ticking from left side of engine
- fordtruck
25 Jun 2012 13:35 #531623
by fordtruck
'77 KZ1000-MTC 1075 kit. Stage 1 port
Replied by fordtruck on topic ticking from left side of engine
Did you check the valve clearance after you bolted on the head? I know Joe sets the valve clearance for you, but you should still check. I had one or two that were pretty darn loose. They were probably safe to run, but I changed shims because I had the ones that I needed.
- brianrae33
25 Jun 2012 23:03 #531749
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic ticking from left side of engine
appreciate all the replies but i took off the cam cover and discovered that 3 of the four cam cap bolts were stripped on my # 1 cylinder exhaust cam...no damage apperent...next question..anyone one know of a decent machine shop to install helicoils in said cap?? :blink:
1982 kz1000ltd
- Thank you received: 2065
25 Jun 2012 23:10 #531754
by Street Fighter LTD
Replied by Street Fighter LTD on topic ticking from left side of engine
Send it back to Joe at Pitstop , or contact Larry C , or find a local machine shop . Its not a hard repair.
- Thank you received: 2829
25 Jun 2012 23:46 #531777
by 650ed
Replied by 650ed on topic ticking from left side of engine
Also, ask about timeserts. Ed
