ticking from left side of engine
- brianrae33
24 Jun 2012 17:50
got about 4 or 500 miles on fresh rings and had the head completely redone from pitstop peeformance on florida...bike runs great but has recently developed a tickiing sound from the right side of the engine...exhaust collars are all tight..any ideas would be greatly appreciated..
1982 kz1000ltd
- MFolks
Re: ticking from left side of engine
24 Jun 2012 18:13
Looked inside the clutch housing lately? Has any work beem done on the clutch, like new parts? I suspect a loose pressure plate bolt or clutch basket nut making the noise.
- MFolks
24 Jun 2012 18:18
The left side of the engine has the magnetic rotor, and some have started to have adhesive failure holding the magnets in place. For ease of mind(get a new gasket for the cover), open up the cover and see if the magnets are loose.
This company in England makes/sells replacement rotors: www.electrexworld.co.uk/acatalog/Online_...ogue_Rotors_188.html
24 Jun 2012 18:53 - 24 Jun 2012 18:54
Title says "ticking from left side"; text says "...recently developed a ticking sound from the right side of the engine..." Which is correct? Ed
Last edit: 24 Jun 2012 18:54 by 650ed.
- MFolks
24 Jun 2012 19:23
That's why I addressed possible noises from both sides. (People get left and right confused with motorcycles and airplanes).
- brianrae33
24 Jun 2012 19:47
left side when sitting on bike..
1982 kz1000ltd
- brianrae33
24 Jun 2012 19:48
no work done to clutch...however will check the rotor magnets..
1982 kz1000ltd
- MFolks
24 Jun 2012 20:42
Any charging problems? Check the tighness of the fasteners on the stator(that's the wire windings)too.They might be the popular Torx(star) or #3 phillips size.
- MFolks
24 Jun 2012 20:43
Check the tightness of the fasteners for the stator(the wire windings)too, they might be the popular Torx(Star) or # 3 Phillips size.
- brianrae33
25 Jun 2012 11:39
just hoping its not the valves chattering being that i just had the head completely redone...anything else i can deal with..
1982 kz1000ltd
- KZJOE900
- Administrator
Super Users
25 Jun 2012 11:53
I have a $5.00 stethoscope I purchased from HF I use to search for engine noises. Would save you some time and work and try to narrow the location of the noise before you start taking parts off. If you don't have a stethoscope, try using a wooden stick (part of a broom handle for example) to put against your ear and use it as sound conduit instead. Or maybe even a piece of PVC pipe (never tried that) may work. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- P21
25 Jun 2012 12:25
might be valve train.
do a compression test
who set the valve clearance?
Kawasaki KZ 1000 Police (2002) P21
