ticking from left side of engine
- brianrae33
24 Jun 2012 17:50 #531476
by brianrae33
1982 kz1000ltd
ticking from left side of engine was created by brianrae33
got about 4 or 500 miles on fresh rings and had the head completely redone from pitstop peeformance on florida...bike runs great but has recently developed a tickiing sound from the right side of the engine...exhaust collars are all tight..any ideas would be greatly appreciated..
1982 kz1000ltd
- MFolks
- Thank you received: 540
24 Jun 2012 18:13 #531480
by MFolks
Replied by MFolks on topic ticking from left side of engine
Looked inside the clutch housing lately? Has any work beem done on the clutch, like new parts? I suspect a loose pressure plate bolt or clutch basket nut making the noise.
- MFolks
24 Jun 2012 18:18 #531482
by MFolks
The left side of the engine has the magnetic rotor, and some have started to have adhesive failure holding the magnets in place. For ease of mind(get a new gasket for the cover), open up the cover and see if the magnets are loose.
This company in England makes/sells replacement rotors: www.electrexworld.co.uk/acatalog/Online_...ogue_Rotors_188.html
- Thank you received: 2829
24 Jun 2012 18:53 - 24 Jun 2012 18:54 #531486
by 650ed
Replied by 650ed on topic ticking from left side of engine
Title says "ticking from left side"; text says "...recently developed a ticking sound from the right side of the engine..." Which is correct? Ed
Last edit: 24 Jun 2012 18:54 by 650ed.
- MFolks
24 Jun 2012 19:23 #531492
by MFolks
That's why I addressed possible noises from both sides. (People get left and right confused with motorcycles and airplanes).
- brianrae33
24 Jun 2012 19:47 #531497
by brianrae33
1982 kz1000ltd
Replied by brianrae33 on topic ticking from left side of engine
left side when sitting on bike..
1982 kz1000ltd
- brianrae33
24 Jun 2012 19:48 #531499
by brianrae33
1982 kz1000ltd
no work done to clutch...however will check the rotor magnets..
1982 kz1000ltd
- MFolks
24 Jun 2012 20:42 #531503
by MFolks
Any charging problems? Check the tighness of the fasteners on the stator(that's the wire windings)too.They might be the popular Torx(star) or #3 phillips size.
- MFolks
24 Jun 2012 20:43 #531504
by MFolks
Check the tightness of the fasteners for the stator(the wire windings)too, they might be the popular Torx(Star) or # 3 Phillips size.
- brianrae33
25 Jun 2012 11:39 #531606
by brianrae33
1982 kz1000ltd
just hoping its not the valves chattering being that i just had the head completely redone...anything else i can deal with..
1982 kz1000ltd
- KZJOE900
- Admin
25 Jun 2012 11:53 #531608
by KZJOE900
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Replied by KZJOE900 on topic ticking from left side of engine
I have a $5.00 stethoscope I purchased from HF I use to search for engine noises. Would save you some time and work and try to narrow the location of the noise before you start taking parts off. If you don't have a stethoscope, try using a wooden stick (part of a broom handle for example) to put against your ear and use it as sound conduit instead. Or maybe even a piece of PVC pipe (never tried that) may work. Good luck.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
- P21
- Thank you received: 34
25 Jun 2012 12:25 #531615
by P21
Kawasaki KZ 1000 Police (2002) P21
Replied by P21 on topic ticking from left side of engine
might be valve train.
do a compression test
who set the valve clearance?
