cam chain to tight
05 Jun 2012 18:58 - 06 Jun 2012 20:00 #527096 by dfinnegan71
cam chain to tight was created by dfinnegan71
OK, so here is the situation. I tore down the engine to replace the base gasket and cylinder head gasket on my 81' GPZ 550. I reasembled it today and while putting the cams on I am finding the chain is really tight. So tight I can't get the cam chain tensioner back in. I turned the bottom crankshft to TDC on 1 and 4 pistons, lined up the EX on the exhaust cam and the Z/5 on the intake so my timing is right. I know this shouldn't affect cam chain tension, So I am wondering three things.
1. Have any of you had this happen and what did you do to fix it?
2. Is it possible the cam chain has come off the crankshaft sproket?
3. Did i possibly put the cam chain guide, twoards the front of the motor, back in upside down or backwards?
You guys have been very helpful and I thank you in advance for your advice. I have read Loudgvx's warning on installing the cam chain tension with the cross wedge installed, but still scratching my head. :unsure:
1981 GPZ 550 mild custom
Last edit: 06 Jun 2012 20:00 by dfinnegan71.
05 Jun 2012 19:29 #527099 by baldy110
Replied by baldy110 on topic cam chain to tight
The chain is not seated correctly on the crank sprocket.
05 Jun 2012 19:41 #527102 by dfinnegan71
Replied by dfinnegan71 on topic cam chain to tight
Thanks Baldy, that's what I thought but was afraid to admit. Now I have to tear it back down and get that chain on correctly, I knew I wouldn't like the answer....
06 Jun 2012 12:07 #527231 by baldy110
You don't have to tear the engine down to fix this. Just remove the cams and hold the chain with your hand as you rotate the engine with the 17mm nut off the rotor. You will know it is seated by how it feels nad turnes over. Very easy to do.
06 Jun 2012 17:26 - 06 Jun 2012 20:01 #527276 by dfinnegan71
Thanks, I took your advice and the chain seems ok down on the crankshaft. Cams back in and cam caps torqued to spec. but apon turning the crankshaft to see if the timing marks line up again, it bound up and got very hard to turn. So i didn't push it, I took the cams off again, checked how the chain felt and moved. The chain seems to move freely. I'm stumped.....?
Last edit: 06 Jun 2012 20:01 by dfinnegan71.
06 Jun 2012 18:14 #527282 by faffi
Replied by faffi on topic cam chain to tight
Which way did you turn the engine? Also, if you turned the engine sans tensioner and the chain is a little stretched, perhaps it's possible for the chain to jump the crank sprocket?
1977 KZ650B1
1980 F1 engine
B1 3-phase alternator
B1 Points ignition
06 Jun 2012 18:51 #527294 by dfinnegan71
I turned my wrench on the crankshaft clockwise. Yes, i did this without the cam chain tensioner installed. I think I should try it again with it installed and it's cap off and crosswedge removed. I don't think the cam chain is stretched as it is on there really shug...almost to snug.
06 Jun 2012 20:20 #527319 by baldy110
It sounds like you fixed the "tight timing chain" but now the cams sound like they are not timed right. Double check your cam timing, DO NOT force it to turn over. If the engine does not turn over frelly by hand there is something wrong, most likely your cam timing.
06 Jun 2012 21:07 #527326 by dfinnegan71
Yes, agreed on the do not force it to turn statement. It appears I am off on my cam pin count by one link. I start on one by the EX line as per the manual and count 1,2,3.....I reach 42 on the Z5 line. Try as I may, I can't seem to get it to 44. It's only one link away! Beacause the chain is so dam tight! I will try and try again but I think that is what I have been getting wrong this whole time. But let me ask again, should I do this with the tensioner in, cap released and crosswedge out or leave the entire cam chain tensioner out of the equation?
07 Jun 2012 03:10 #527404 by dfinnegan71
Frustration, clueless... Two words describe me right now. It's 2am I have been trying this over and over. I can get the cams lined up according to the book. I can count over 44 pins on the cam chain. I tighten down the cam caps, give a turn with my 17 mil wrench on the crankshaft and it turns about 85% around and it just doesn't want to go anymore....WTF!??! I can't figure it out....clueless.
07 Jun 2012 07:27 #527426 by Powerstroke_fan
Replied by Powerstroke_fan on topic cam chain to tight
Iam not sure about the 550s but are you sure that your on top dead center for 1&4? and you will want to make sure the adjuster and everything is in place before you rotate the engine over by hand. If not it will just jump time.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
07 Jun 2012 11:50 - 07 Jun 2012 11:51 #527466 by baldy110
Pull the cams back out and see if the engine turns over freely without them, all the valves will be closed so it will tell you if it is your cam timimg or something else. Also when you are counting the pins the number 1 pin is not the one that lines up with the exhaust that is pin number 0 the next one up is pin number 1. Do not turn the engine over without the timing chain tensioner. Like Powerstroke said get it all together, line everything up triple check everything then turn the engine over.
Last edit: 07 Jun 2012 11:51 by baldy110.
