- Thank you received: 1
open headers?
- KZCool
1976 KZ750 hardtail
- krazykzcommandeered
79 kz650 cafe rat racer
aka catchup
- Hollywoodmx
- Thank you received: 16
KZCool wrote: :laugh: you've got a good point. Love your bike like it is the most expensive thing you own and it'll run fo eva!
No wives are..
Save up for an exhaust..
- 82 GPz1100injection
- 77 Kz1075 Supercharged
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
and ready to ryde, sry buddy ill be down to visit soon bro.
aka catchup
- steell
As long as the pipe is 20" long off each cylinder you'll be ok.
With really short or no pipes what happens is the cold air can get to an open valve after you shut it down while hot, causing a valve to warp. Since a warped valve no longer seals, the exhaust getting by the warped valve will burn it.
Might hole a piston running it so lean though.
warping a valve it what i was worried about, i just try and keep in mind not to let off the throttle suddenly,
aka catchup
aka catchup
- Hollywoodmx
Yup, it's called un-metered air in the fuel injection world.
Basically the exhaust pipe is going to take in air through "reversion" (like a vacuum), since that air isn't flowing through a carb or air flow meter no extra gas is accounted for so you facilitate a lean condition. Same thing can happen on with a cracked carb boot on the intake manifold side of a carb or a vacuum leak.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- steell
Are you saying that cold air is going to travel up a 20" long pipe, plus a couple more inches of port, and hit the valve while the motor is running?
- Hollywoodmx
I didn't pay attention to the pipe length in the thread just read they were short, 20" should be ok but too many factors for me to say, just call it a risk when you run short pipes no collector, etc.
- 81 Yamaha TR-1
- 81 Yamaha xv920
Calgary
- Thank you received: 2829
The theory goes like this: With no collector there is no scavenging affect. Scavenging helps pull exhaust gases through the pipe, and this helps draw hot gases away from the exhaust valves. With no scavenging affect the valves tend to run hotter and depending on the engine, valves, and state of tune, the valves can overheat and warp leading to burned valves. While one sees open pipes with no collector on some types of racing engines they are not intended to run thousands of miles without being stripped and rebuilt, so the open pipes and the possible burned valves are not a concern (the valves don't burn in a quarter mile). Ed
- zukdave
- Thank you received: 229
then it gets rebuilt between rounds.
At 10,000 rpm for under 4 seconds it only turns around 800/1000 rev.'s
per pass.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
