creamy white goo on the underside of the oil cap
  • donthaveakawman
  • Topic Author
  • Visitor
15 Mar 2012 23:20 - 15 Mar 2012 23:20 #509942 by donthaveakawman
creamy white goo on the underside of the oil cap was created by donthaveakawman
:ohmy: i just changed my oil for the 3rd time in 2500 miles(since June) and now there is a problem, i don't know if it is because the oil filter seal didn't set right and i lost a quart of oil as soon as i started it up (fixed and filled immediately)-
or if it is a problem with me riding it in the rain. all the vacuum hoses seem to be in order, although there is a mild misfire under the seat and im sure the egr might be getting some gas back in it if its backfiring like it is. maybe a valve adjustment is in order. anything i should know if this is my first time on a kz? do the cams have to come up? problem signs i should look for on the cam chain?
here is my guess on how to do this please revise and proofread before i actually get into it
1. pull the gas tank
2.pull the valve cover
3. put a feeler guage between the cam and lifter/follower
4.pull a half of a cam at a time to insert shims under followers/lifters
5. insert correctly measured shim under lifter
6.put it all back together and check for clearance
7. reinstall valve cover vacuum hoses and gas tank
8.warm it up and dont pop a wheelie.
if anyone knows that i would screw this up by any reasonable measurement or if anyone doubts my abilities and feels that i might wreck myself i would really like to know. thanks for your in depth input/help i really dont want to wreck myself.
viva la kawabunga, rally mcnally
Last edit: 15 Mar 2012 23:20 by donthaveakawman.
  • donthaveakawman
  • Topic Author
  • Visitor
15 Mar 2012 23:21 #509943 by donthaveakawman
Replied by donthaveakawman on topic creamy white goo on the underside of the oil cap
thank you thank you
15 Mar 2012 23:35 #509948 by Patton
Am thinking due to condensation resulting from not running long enough to evaporate moisture in the crankcase.
Good Fortune! :)
16 Mar 2012 00:31 #509959 by RonKZ650
Yea, don't make white sludge under the cap into a worry. Completely normal unless you happen to live in Hawaii during winter. Cold weather this will always happen in cold weather at least on the air cooled KZs
  • donthaveakawman
  • Topic Author
  • Visitor
16 Mar 2012 00:38 #509960 by donthaveakawman
so i found a 85 gpz750 for sale nearby i would like to know if the motor mounts are the same.
16 Mar 2012 14:25 #510034 by Mcdroid
donthaveakawman wrote: so i found a 85 gpz750 for sale nearby i would like to know if the motor mounts are the same.
As what?
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
16 Mar 2012 15:48 #510043 by Powerstroke_fan
Replied by Powerstroke_fan on topic creamy white goo on the underside of the oil cap
If its a kz with shim on top buckets you dont have to pull the cams to change shims. You can buy a shim tool saves a lot of time and chance of stripping threads or anything like that. but like previously stated dont worry about the white buildup. just run it for a good while to get the moisture evaporated out.
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
  • donthaveakawman
  • Topic Author
  • Visitor
16 Mar 2012 16:39 #510049 by donthaveakawman
same mounts as a kz mcdroid if the kz had the gpz engine they could rule the world. especially with the shim under bucket tappets.
16 Mar 2012 18:42 - 16 Mar 2012 18:48 #510065 by TexasKZ
Year, model and displacement of both bikes is needed before anyone can answer the motor mount question because the KZ came with 1, 2, 4, and 6 cylinder engines from 200 - 1300 cc. The GPz came with a 4 cylinder engine from 550-1100cc and there is an 1100cc water cooled version, too.
The large displacement KZs can be converted to shim under bucket, so you can rule whatever you like without an engine swap.
If you bike has shim under buckets, then the cams have to come out. If you have shims on top, then the cams stay in place. In either case, I'm not sure how you could get half a cam out.
A factory shop manual would be a very wise investment. It will save many time its cost. There may even be somebody around here with an electronic version they'd be willing to share.
Last edit: 16 Mar 2012 18:48 by TexasKZ.
The following user(s) said Thank You: BlackZ1R
16 Mar 2012 21:52 - 16 Mar 2012 21:54 #510102 by zukdave
The Gpz motor is a bolt in with adding some spacer's.
The 83 Gpz 750 motor in my 80 KZ650 F1
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
Last edit: 16 Mar 2012 21:54 by zukdave.
  • donthaveakawman
  • Topic Author
  • Visitor
17 Mar 2012 18:36 #510255 by donthaveakawman
i put the stock air filter back in my kz750 h1 it seems like it does much better than the k&n i noticed it is hard to oil the k%n properly.
i guess the gpz has a rubber motor mount on the front that i read about in the
www.motorcyclespecs.co.za/model/kawasaki...aki_gpz750f%2085.htm
website
along with the antidive forks, hmmm why dont i just try to get a title for the parts bike?
  • donthaveakawman
  • Topic Author
  • Visitor
17 Mar 2012 23:08 #510301 by donthaveakawman
i have already made up my mind that it is not the head gasket.
