- Thank you received: 299
Cleaning combustion chambers...thoughts??
- donthaveakawman
- Visitor
- wireman
Actually I have closer to 20,000 posts on here in the last 10 years and have built more big bore 900/1000 plus size motors in the last 20 plus years than many people on here have ever started.donthaveakawman wrote: your clutch resides in your engine oil, so there is a special kind of oil that you can use that is called motorcycle oil(with wet clutch protection). come on man your profile shows you have over 3509 posts on this forum, are you agreeing with me so you can agree with me when i explain what it is i am talking about? :huh:
Ive been using synthetic oil in many motors for close to 30 years,you know the same stuff people have been saying for 30 plus years causes clutches to slip without an oil related clutch issue.
Ive also run just about every other kind of dino bone related oil in differant motors without an oil related clutch issue as well,the clutch issues I tend to come across repairing other peoples motors tend to be caused by lack of general maintenance like the inability to properly adjust a kawasaki clutch cable at the 3 seperate points on the cable.
Which in turn leads to clutches getting hot,warping the steel plates and glazing of friction plates.
Another problem I see is people not changing oil/filters ,I dont care how many additives your oil has or doesnt have if you dont change it when its dirty all the trash gets worked through the system including the clutch and screws stuff up.
- wireman
Moose huh?donthaveakawman wrote: you don't want to mess with me right now, as you can see i have changed my profile picture to a moose. if you run over a moose it is not going to stop the moose if he is big enough, dipstick...
I loved you on that pep boys brake pad commercial!
Personally I consider myself a hemmeroid,and everybody knows the affect a hemmoroid has on an asshole! :sick: :woohoo:
- wireman
Why not just install a k&n replacement filter inside the stock airbox?donthaveakawman wrote: i'm thinking my gm hei module could use a rewiring and hidden from the rain maybe under the seat.
a thought about individual pod filters instead of a k&n in the airbox; a person could move the airbox forward, take the carb connectors out and hide the individual filters inside the airbox then move the airbox forward- along with removing the filter and screw on cap. stage 3 jet set here we go... mostly to hide the filters from theft and the elements.
- wireman
Thats why Im asking you o wise one,so have you had this happen or not?donthaveakawman wrote:
wireman wrote:
Have you seen sea foam eat through clutc plates? :whistle:donthaveakawman wrote: sea-foam will eat right through the lining of your clutch. What would the children think if you had to walk home because your clutch isn't working, huh? :kiss:
i wouldn't knock it if i handn't tried it.
- wireman
donthaveakawman wrote: every time i get a good pull in 2nd or 3rd gear i end up loosing my clutch night about 2/3 through the powerband and taking it well into the redline. there is plenty of play in my clutch cable.[/quote
Your clutch is/was slipping.
Did you remember to take up the slack in the bottem adjustment through the clutch cover first then at the clutch lever then do final adjustment in the center of the cable?
- donthaveakawman
- Visitor
- donthaveakawman
- Visitor
- wireman
Im just replying to your posts,youre the confusing one! :laugh:donthaveakawman wrote: i've had about enough out of you, you are confusing. :huh:
- wireman
Well you quit acting like an internet tough guy,and Ill stop talking about bringing assholes to a screaching halt! :woohoo:donthaveakawman wrote: can you keep it clean, i don't want to hear about hemorrhoids.
- DoubleDub
- Visitor
- Del_Herring
Remember kids, don't feed the trolls.
1983 KZ750-N2 Spectre
