Cleaning combustion chambers...thoughts??
- BRABBIT04161991
Re: Cleaning combustion chambers...thoughts??
21 Oct 2012 03:06
I just ad seafoam to the oil and double check my oil everyday until it's a milky brown then change the oil never had any problem with seafoam before and it does the same things as force feeding the carb. The only better thing would be not blowing thick white smoke everywhere lmao
- donthaveakawman
21 Oct 2012 03:29
when you, grasshopper, can snatch this forum from my hand you will be zx ninja. do not put sea foam in your oil of your bike.
- LarryC
21 Oct 2012 10:33
Oooooooooo somehow I just knew this was going to be good :woohoo:
Larry C.
- wireman
21 Oct 2012 13:24Why not?donthaveakawman wrote: when you, grasshopper, can snatch this forum from my hand you will be zx ninja. do not put sea foam in your oil of your bike.
I just find an open stretch of road and run the hell out of it to blow the carbon out
- wireman
21 Oct 2012 13:28What in the world are you talking about? :woohoo:donthaveakawman wrote: step 1:i would pour engine oil 10w30 down the carburetor while its running then turn it off then spray the entire engine compartment with degreaser then pull the spark plugs then have a battery charger on the battery then have someone turn over the engine with the coil disconnected
step2 :then spray carburetor cleaner into the intake a few cans will do
if you value your engine then skip step 1
- donthaveakawman
- donthaveakawman
21 Oct 2012 15:30
sea-foam will eat right through the lining of your clutch. What would the children think if you had to walk home because your clutch isn't working, huh? :kiss:
- donthaveakawman
21 Oct 2012 15:35
this stuff is way better than dumping a half-a-bottle of Lucas Fuel System Cleaner in there, that is how i lost my exhaust baffle.
- 4TheKZ1000
21 Oct 2012 15:50 - 21 Oct 2012 15:50
:dry:
:dry:
Attachment th_2012-10-21.jpg not found
:dry:
Last edit: 21 Oct 2012 15:50 by 4TheKZ1000.
- wireman
21 Oct 2012 16:20 - 21 Oct 2012 16:22Have you seen sea foam eat through clutc plates? :whistle:donthaveakawman wrote: sea-foam will eat right through the lining of your clutch. What would the children think if you had to walk home because your clutch isn't working, huh? :kiss:
Last edit: 21 Oct 2012 16:22 by wireman.
- wireman
21 Oct 2012 16:21 - 21 Oct 2012 16:23That still doesnt explain what youre talking about! :woohoo:donthaveakawman wrote: this is a motorcycle forum.
Last edit: 21 Oct 2012 16:23 by wireman.
- donthaveakawman
21 Oct 2012 19:34
go ahead and pour some wd-40 in your crankcase the next time you change your oil instead of wet clutch protection motor oil with sea-foam, it will most likely last about the same length of time.
