[SOLVED]Engine break-in....stalling...overheating?
Re: Engine break-in....stalling at stop...overheating?
06 Jul 2011 19:17
What carbs are you running? Would this work for you? (see link)
cgi.ebay.com/ebaymotors/NOS-KAWASAKI-FLO...fPartsQ5fAccessories
- ELCouz
06 Jul 2011 19:21
Mikuni BS34 carbs this won't fit.. nice find btw !
Thanks good to know!
regards,
laurent
the two other 'barb" are vent lines not overflows
regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
- ELCouz
07 Jul 2011 11:49 - 07 Jul 2011 11:50
IIRC, bubble either comes from bad drain screws (sucking air) or when filling the test tube air stays in the U in the middle... can i tap the tube or it might upset the carb float needles??
How many turns you screw them out [the drain screws]? After a few it start to drip fuel from the threads...
Do anybody know where to purchase them beside the dealer (charge me 10$ each :blink: :pinch: and this is just the screw.. no o-ring on it!!!)?
My package should arrive today ! :woohoo:
regards,
laurent
regards,
laurent
Last edit: 07 Jul 2011 11:50 by ELCouz.
- loudhvx
07 Jul 2011 15:20
Yes, bubbles do tend to be a problem when doing fuel level tests. If air is sucking in through a screw seal, then it needs to be fixed. But also to prevent air bubbles sticking in the tube, you want to go to at least 1/4" ID clear hose as close to the connection point as possible. I just jam the small tube into a bigger tube. It seals ok for the test.
If you use a skinny tube, you will have to play all sorts of games to make sure the air is out. Also, make sure to use a clear tube so you can see what's going on.
If the vent ports are above the floor of the carb bore, then they are only vents. The carbs will overflow into the bore before any gas comes out of the vents. If the vents are below the bore floor, then they will act as overflows.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- loudhvx
07 Jul 2011 15:22
1981 KZ550 D1 gpz.
Other links.
Other links.
07 Jul 2011 15:33 - 07 Jul 2011 15:35
When I wanted to check my fuel level I just used an old carb drain screw and some Home Depot pieces to make a tool. I had no problems with bubbles or leaks or anything else. You just screw it snug into the drain hole and turn on the petcock. I've seen similar items on eBay since making mine.
Attachment carbtool.JPG not found
Last edit: 07 Jul 2011 15:35 by 650ed.
- ELCouz
08 Jul 2011 00:01 - 08 Jul 2011 00:02
Wow nice adapter there 650ed!
My package has just arrived!
Tomorrow i will take the carb off and check fuel level...
Is there anything else i should check for, while the bike is partially disassembled?
I will install new coils and spark plug wires too!
I want to be sure carbs are clean as new (they were cleaned 6 months ago)...should i soak them in a carb cleaning solution overnight? Usually i just blow air in passages and clean with thinner bowl and jets.
Btw, Thanks for the info Loudhvx, i will get a bigger tube diameter
regards,
laurent
regards,
laurent
Last edit: 08 Jul 2011 00:02 by ELCouz.
- ELCouz
09 Jul 2011 14:48
OMG!
Goof of the year Award 2011 comes to:
Me
For: Putting the wrong head gasket in the engine... installed the 750 one (came in the Vesrah complete gasket kit) instead of the wiseco 810cc one!
/me wants to pull the trigger and kill myself
One step forward 5 step backward %%^&*^#@
I must fix that before fixing the carbs issue!
Last time it was missing (2) knock pins so i pulled the head again.. P.O. lost them and i didn't check the exploded view to see if something was missing...every goof i made the engine was working correctly its just wrong for me to leave this like that.
Keep you informed once carbs are done!
regards,
laurent
Me
regards,
laurent
- mark1122
- Keep twisting it
09 Jul 2011 19:06
about the oil cooler fittings.
i am not formiliar with your bike, but an image came to mind. u said it had a flange with 2 bolts. could u cut a 1/2" thick alumin plate to bolt over the hole and drill and tap the plate for a hose barb ?
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- ELCouz
09 Jul 2011 20:48about the oil cooler fittings.
Wow great idea...never thought of that! Easy to do
thanks!
Ok after re-installing the head...check all 4 carbs for fuel level they were all at within specifications (3mm +/- 1mm)
Looking good for that!
Next is main jet size increase, currently have #110 and bought #120 and up oops!...
regards,
laurent
- mark1122
- Keep twisting it
10 Jul 2011 13:44
why not take it for a spin before u start changing more things. your problem is not with the main jets right now.
will you do us a big favour.
get the bike running, spray wd40 around the intake boots and listen for a change in rpm. then do it again when it is hot. if the rpm changes u have an air leak and a resolution to the bigest part of the problem.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Godfrey
10 Jul 2011 14:44
Right on Mark, I mentioned I had the same issue, I did wait till the engine was good and warm( I use carb cleaner instead of wd40 cause I don't care for the mess), mine didn't rev but it dropped a couple hundred rpm when I hit the 2 center carbs where the carb enters the manifold,and the effect is the same , theres a leak, so I will be ordering a new set of manifolds Monday. In the mean time, I can install a new rear tire, as the old one is about worn out and went flat last night.
1981 650CSR frame
1980 KZ750E engine
1980 KZ750E engine
