[SOLVED]Engine break-in....stalling...overheating?
- ELCouz
Re: Engine break-in....stalling at stop...overheating?
29 Jul 2011 01:14 - 29 Jul 2011 01:15
Big update: Issue is fixed !
Installed #130 main from #125, engine run cooler in overall.
Did a little adjustment for carb sync and found the minimum stable idle is 1200 rpm (increased mass maybe ? (pistons are bigger))
Re-calibrated the pilot mixture when hot with colortune...
Now it's running fine
Thanks everybody!
Finally, i can nail the long thread
Best regards,
laurent
EDIT: oh yeah and no new carbs are needed
Thanks everybody!
Best regards,
laurent
1982 KZ810-R1 GPZ with hindle 4-into-1 pipe
Last edit: 29 Jul 2011 01:15 by ELCouz.
- loudhvx
29 Jul 2011 11:55
Man that is weird. That little jet change made for all of those symptoms? The oscillating idle and everything else? :blink:
Oh well, as long as it's fixed !
Still got half a summer to ride!
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
- ELCouz
Re: [SOLVED]Engine break-in....stalling...overheating?
29 Jul 2011 12:00The oscillating idle
I think it was clutch related... i could hear the primary chain rattling on first gear at red lights.
Adjusted the slack (less than 1 turn out) on the clutch lever... rattling was gone and unstable idle...
Maybe a little bit of friction from the clutch kept the engine under a little skippy load and at trouble to keep the idle right...
That's my hypothesis
regards,
laurent
- nads.com
30 Jul 2011 03:22 - 30 Jul 2011 03:34
I started reading this lonng post and got to page 4. SIGH :dry:
Bout page two I'm thinking this poor lad is lean.
Two needle clip positions is alot. 4 pilot turns is alot.
The bs34's
Bless those power makers, need a wide open throttle test repeated with adjustments to the pilot start out lean and open it till it pulls to redline the strongest. Those tiny jets :blink:
NEED FUEL?
WANT FACE LIKE THIS :woohoo:
how bout one for each gear :woohoo: :woohoo: :woohoo: :woohoo:
BS34's
The bs34's
NEED FUEL?
BS34's
Last edit: 30 Jul 2011 03:34 by nads.com.
