Need help from engine experts on cam shaft binding
  • Dale65
  • Topic Author
  • 1981 KZ 550 LTD
04 Feb 2011 07:01 #428347 by Dale65
Hey, guys. Need some advice here. I was fixing oil leaks on my '81 kz550, so of course the cams had to come out. When I put everything back together (per the manual) and got it all lined up, it will only turn about a half turn clockwise and not the full two turns as the book says it should.
I'm turning it from the right side, 17mm nut, clockwise. I backed it back up counter-clockwise and it will turn fine there, but I know that's wrong, it has to turn clockwise.
I took the cams out twice and made sure the chain wasn't bound up and also checked my timing marks and counted the chain links per the book, but no go.
Help!!!
1981 KZ550 LTD stock for now, but soon to be a cafe racer.
04 Feb 2011 07:05 #428348 by TerryK
Are you sure you are not 180 degrees out with the crank rotation?
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • Dale65
  • Topic Author
  • 1981 KZ 550 LTD
04 Feb 2011 07:18 #428353 by Dale65
I followed the markings in the manual to line up 1 and 4 to top dead center.
  • testarossa
04 Feb 2011 07:22 #428355 by testarossa
Are your spark plugs in or out?
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
  • Dale65
  • Topic Author
  • 1981 KZ 550 LTD
04 Feb 2011 07:24 #428356 by Dale65
Out.
04 Feb 2011 07:28 #428357 by TerryK
Line everything up as per spec and take some close up pictures for us.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • testarossa
04 Feb 2011 07:29 #428358 by testarossa
Ok so it's not just compression. Sorry, I had to check. Is the bike in neutral? Just trying to rule out stuff. Does it turn freely without the cams in place? Do you have the tensioner out?
2004 ZX-10R
Angola, IN
04 Feb 2011 07:30 #428359 by turboguzzi
even if he was 180 out, the engine should still turn, the sparks would simply happen at the wrong time (just switch coil wires to remedy :) )
Dont quite understand: can you turn counterclockwise as many turns as you want and it locks up only going clockwise?
could be one of the cam chain sliders becoming dislodged
have you already tensioned the chain?
as testa says, do everything with plugs out, the compression will simply create confusion...
  • Dale65
  • Topic Author
  • 1981 KZ 550 LTD
04 Feb 2011 07:38 #428365 by Dale65
No prob. Total rookie with engines, so all questions are good. I may very well be looking over the obvious, like if it is in gear. I didn't actually check, but I know the back wheel turns freely cause I have it off the ground and I bump it daily. But I will double check to be sure.
I haven't tried without the cams. Didn't know if it was OK to do that. I did try it first without the tensioner and then again with the tensioner. Which way is best?
  • Dale65
  • Topic Author
  • 1981 KZ 550 LTD
04 Feb 2011 07:39 #428367 by Dale65
Yes, it turns counter-clockwise fine, many turns. But clockwise only about half turn, then total lockup.
04 Feb 2011 07:44 #428371 by Patton
Dale65 wrote:
...was fixing oil leaks on my '81 kz550, so of course the cams had to come out....
:unsure: What type oil leak repair necessitated removal of the cams?
Good Fortune! :)
  • Dale65
  • Topic Author
  • 1981 KZ 550 LTD
04 Feb 2011 07:47 #428374 by Dale65
Good Fortune! :)
Cylinder head. Was hoping you'd pop up, Patton.
