- Thank you received: 82
Need help from engine experts on cam shaft binding
- testarossa
2004 ZX-10R
2007 Harley Sportster 1200
Angola, IN
- Dale65
- 1981 KZ 550 LTD
Line everything up as per spec and take some close up pictures for us.
Here's a pic. Can't see the markings, but you can see position of cams.
EDIT:.. sorry, pic too big and won't down load.
1981 KZ550 LTD stock for now, but soon to be a cafe racer.
- Dale65
- 1981 KZ 550 LTD
Not positive on the procedure for the 550's but I believe that you set the cam timing without the tensioner, and then install/adjust the tensioner after the camshafts are bolted down.
That was the first way I tried it. When it didn't work, I thought I did it wrong so I put the tensioner in. I'll take it out tonight and check it again.
- Thank you received: 2098
Perhaps could edit pic size and re-post.
I use MS Paint program to re-size, but there are many other good re-sizing programs also readily available.
KZr pic size limits:
Width: 2400px
Height: 1200px
2048kb (2 MB)
Am meanwhile looking for loudhvx's KZ550 site which has excellent advice about cam installation.
- Dale65
- 1981 KZ 550 LTD
Attachment Eng.doc not found
Click > home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
- testarossa
2004 ZX-10R
Angola, IN
- Dale65
- 1981 KZ 550 LTD
Could the tach drive gear be binding on the exhaust cam? I'm grasping at straws here. In any case, just pull the tach drive gear to rule that out.
I didn't have the tack gear in at that time. Good try though!
Here's another try on the pic.
Got this to appear on screen:
[Click on image to enlarge view.]
- Dale65
- 1981 KZ 550 LTD
Click > home.comcast.net/~loudgpz/GPZweb/index.html#home
Great links, Patton, thanks. I did see one thing that looks suspect. There was an error, according to your link, that showed in the Clymer manual where the mark should be at pin 1 but is on pin 0 instead on the exhaust cam. Is that enough to not allow it to turn more than half a crank? But it turns fine in the opposite direction, so why is that you think?
- Dale65
- 1981 KZ 550 LTD
Darn, forgot to resize it.
Can't resize with what I got on my work computer, so it's in the link.
Attachment Eng2.doc not found
