- Thank you received: 1
Look what I made.
- 550A2
- keep the shiny side up
I was just going to say that... But I scrolled down further.
no need for em up here, no emissions testing where i live
82 Honda ATC 200-sold
82 Yamaha Virago 920-sold
82 Yamaha YZ250j-kept
80 Suzuki GS 550-sold
82 Kawasaki KZ550 A2-ride all the time
79 Kawasaki KZ650 C-sold
73 Kawasaki Z1 900E-paid $200, sold $6000
86 Yamaha Radian YX600-new project
- 550A2
Do you not want to ventilate your crankcase pressure?
The crankcase vent is under the airbox....
how about just casting them? no structural need to carve them from plate or billet
Never done any casting before....I dont really have the tools to do it.
- notaduc
- Thank you received: 3
Unless you are doing huge runs of them, the machining process is wasteful, or both, no sense in casting.
These specifically are very simple with little waste, and you would have to machine the mating surface on a cast piece either way.
Not a good candidate Id say.
1980 (mostly) KZ1000
- PLUMMEN
- Thank you received: 104
- notaduc
i could have the kids in local high school shop class cast those and hit the bottem side on a belt sander,no fancy machining required for about $1.00 a piece
Yea.
You could just cut a piece of bar stock to length and drill the holes too.
I wouldnt be satisfied with either, nor would I put my name on them. Ill leave making the fastest crappiest parts possible to the folks selling china junk on ebay.
Still not a good candidate for casting.
- PLUMMEN
id say those pieces are a lot higher stressed than those smog covers are and casting seems to work fine for them!
i used to run the maintenance department at the foundry down the street ,and i still do special fab projects /welding around the plant for them the maintenance guys cant do.
id cast you a bunch down there but they only work in iron at that plant,but i still help out at my old high schools shop class from time to time and have absolutely no doubt those pieces could be sand cast from aluminum and cleaned up with 5-10 minutes of belt sander and drill press time to punch the holes.
just because you apparently dont have the abilty to make a very simple part without a cnc machine or paying somebody else doesnt mean the rest of us lack the skills to do it! :laugh:
- notaduc
I never said casting was crappy. but having High Schoolers cast them from recycled soda cans and bumping them on a belt sander seems like the long way around to not so good.
Im not sure if you were trying to insult me with the assumptions of my abilities, but I have been a metal worker professionally for years, including foundry work, programming/operating cnc equipment, welding etc.
5-10 minutes on the mill and I'll cut you a perfect pair with your name on them, guaranteed set up time is shorter than sand casting.
Or 5 minutes and you can have one made from bar stock.
If I was going to cast them for what ever reason, Id investment cast them.
All this said, I appreciate a company like APE, and buying a set from them would also suit me.
- PLUMMEN
notice i said without fancy machines? you were the one who said cheap chinese junk and ebay,not me.Wow, defensive?
kids in shop class dont always use old beer cans,ive donated plenty of old pistons and old junk engine and trans cases over the years for the cause .
not all high school shop classes teach kids to do half ass work.
- notaduc
- PLUMMEN
anybody got a stock smog cover i can use as a pattern?
- notaduc
ill make my own ,ive got an old set of trw's ill donate to the cause! :laugh:
I have a pair. You are welcome to either, or both.
- PLUMMEN
