TOP END CLEANER?
- larrycavan
- Visitor
If an engine had heavy carbon on the back side of the valves, it's time for seals and quite possibly guides anyway.
When that carbon comes loose, some of it has to get mashed between the valve face and the seat. That's never a good thing.
To me, if you're going to go that route, you may as well take a little extra time and to the coil mod also. One good band-aid deserves another
JMO
Larry C
- beefsquasher
Assuming you do succeed in loosening carbon particles from the valves, pistton, combustion chamber etc...
Where does all this junk go? 3 places.
- Washed down in between the piston and cylinder where it can jam ring gaps, ring grooves and score the cylinder (rock-hard carbon can actually scratch steel and act as a nasty abrasive!)
- Smashed between the valve and the seat where it holds the valve open or diminishes the ability to retain a good seal.
- Out the exhaust (you hope).
Do it right. Physically remove the carbon by taking apart your engine and cleaning it, then address the reason you have carbon buildup.
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- Thank you received: 2829
- Thank you received: 2098
Click > kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=357990
- TeK9iNe
- What did you do!?!
2 cents from me
JMO
Larry C
:laugh: :laugh: :laugh:
I agree with beefsquaher sort of...
I was taught (by some racers :blush: dont thrash me), that a properly tuned engine will build up carbon "where it is supposed to".
Like the carbon ring that forms around the top of the cylinder, and how it actually does improve compression.
You can take apart a stock engine in good tune, clean all the carbon and carbon ring out of it, (not replace a thing) and you actually lose some compression till the carbon builds back up, which usually takes a while.
If your compression is good, and engine is tuned well, then why run crap through it to remove carbon?? I don't get it? It seems like a cash grab to me.
I've got a Toyota 1.5 liter with 367000 miles. Never ran any cleaner crap through it... still has good compression.
Got old bikes that have been running for 30+ years on origional equipment. Still have fantastic compression - no cleaners used, just changed oil seals. thats it.
WHY CLEAN? i dont get it? less you cant tune an engine! :laugh:
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- otakar
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=369254
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- PLUMMEN
- Thank you received: 104
But the FSM suggests such possibility and the remedy of disassembly and de-carbonizing pistons heads, etc.
Says built-up carbon on the piston reduces cooling capability of the piston and raises compression, leading to overheating which could possibly even melt the top of the piston.
- larrycavan
- Visitor
I don't condone that process but there are budget constraints sometimes.
In fact, I encourage everyone to use it before they ship me the cylinder head. I would love it if every head came in that clean.
Oh...and Patten...if you dive further into the manual, it tells you to check and replace the worn out parts that caused the carbon build up to begin with :woohoo:
