TOP END CLEANER?
- otakar
kzrider.com/index.php?option=com_kunena&...ew&catid=2&id=369254
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- bountyhunter
- Thank you received: 337
Another way to clean, is to use water. It creates steam and that does the cleaning. Hold the throttle open to get around 3K RPM and add a small quantity in the intake, the power brake vacuum line is a good spot.
You say new Catalytic converter, but did you replace both the up and down stream O2 senors?
We had the injectors and manifold taken off and cleaned less than 5k miles back. I have not tried shotgunning the O2 sensors or MAF sensors. That starts to get pricey because I am too old to do the work and recently have had severe back problems. If I have to pay to have the work done, it probably exceeds the value of the car.
BUT: I am not convinced it would pass even if I did that. The state arbitrarily dropped all the emission limits about 40% to a level this car was never designed to meet. The HC limit that it is failing is 65 PPM at 25 mph treadmill test (not simple idle test). This car would have passed the former limit (105 PPM), because it's reading about 85 PPM. Now, it's failing. The state government has been on a campaign to force all the old cars off the road.
- bountyhunter
Thanks, that was the thread I was remembering existed somewhere.I think that you are looking for this thread. I explain exactly how I do it on there.
- Motor Head
- Thank you received: 391
I hear you on the bad back, mine hurts 24-7. Old age I guess, with to much heavy lifting when young.
- bountyhunter
I did the Seafoam thing today into the intake manifold and killed a few billion mosquitos with my crop-duster drive through the neighborhood as the garbage blew out of the engine...:laugh:
- KZ250LTD
- Thank you received: 16
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- Motor Head
O2 sensor can be tested quite easy with a DVOM, or better a scope. Yours will make a voltage from 0-1 volt dc. Your computer keeps changing the Air/ Fuel Ratio slightly looking to the O2 for a response, rich lean cycle. The O2 uses the inside the pipe oxygen to compare to the outside air, it will have a switching wave signal. As the computer sees the results it then changes the Pulse width to the injectors to set the fuel ratio, depending on many other conditions of course. But this guy is what fine "Tunes" the A/F Ratio, as it is there to protect the Cat, a perfect 14.7 to 1 is what it would like.
I hope that Seafoam is both sensor safe and Cat safe, so no harm was done.
- bountyhunter
I think Seafoam is sensor safe, I also used that "pass or don't pay" cleaner which is guaranteed sensor safe. I put about 2/3 can in the gas tank and sucked about six ounces directly into the manifold.
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- beefsquasher
I frequently rebuild motorcycle engines as part of my job and as a hobby. The hard carbon buildup in the combustion chamber and on the piston dome needs some serous soaking in something a little stronger than $%$@!$ seafoam (like carb cleaner or gasket remover) as well as some quality time with a stiff brass brush in order to remove it.
The deposits on the valves are the worst - they are ROCK HARD and they remain untouched by solvent of any description. The deposits on the exhaust valve and in the exhaust port are especially bad (and I fail to see how any cleaner that you pour in the intake does anything to the exhaust valve or port - It's already burned!). Wire wheel or beadblast for them (don't forget to mask off the stem!).
There are very few things that will clean an already dirty combustion chamber besides mechanical force.
Many of these cleaners work well with fuel injected systems b/c they can clear out fuel injectors that do not have hard carbon buildup, rather, they have gummed fuel on the injector pintle from hot-soaking after the engine turns off.
Here's how to clean your combustion chambers and keep them clean - disassemble top end. Clean. Reassemble. Ride hard, plenty of highway trips with a good load on the engine. Use good premium gas while avoiding the temptation to add some special potion to every tankful. Don't run too rich and make sure you don't have oil sneaking past weak rings, grooved cylinders, or loose valve guides and seals.
Just my screwed up opinion though.
I would also like to see some before - after comparisons with some of these cleaners. Leakdown, compression, dyno test, borescore pictures - anything besides "well I used it and now my bike like super fast and its awesome man"
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- Old Man Rock
- Thank you received: 225
Got me thinking about another thing based on what you wrote... In using Seafoam for example, brakes up the carbon build and basically run it through the exhaust...
Well with this carbon build up particles being broken down for no better choice of words, I would think where some of the carbon particles have a potential of ending up trapped in your valve components, possibly under the valve/seal?
Seems fairly possible no?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
