- Thank you received: 300
Can I use newer stock cams to boost my 78 kz1000?
- Nebr_Rex
Nebr_Rex wrote:
what comes in must go out at some point :laugh:How about just a slightly bigger intake cam and leave the exhaust alone.
kzrider.com/index.php?option=com_kunena&...d=2&id=261617#262838
kzrider.com/index.php?option=com_kunena&...25867&catid=2#325867 :woohoo:
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
- larrycavan
- Visitor
OK so would DFIGPZ's GPz Cams require mods to fit or not? I'm not understanding that.
Hey Old Man Rock - yes I thought about dropping the gearing, but I really don't want it turning any faster on the freeway. I'm happy with the current gearing.
www.kzzone.com/sprockets.html Link to the sprockets you need to run GPz cams.
- Nelson
ACS1100K $49.95
Adjustable Cam Sprockets (one pair) - Kawasaki 1000J / GPZ1100 adapter sprockets.
And will the GPZ cams raise the powerband higher in the rpm range, losing power at lower rpms? I won't like it if so. Thanks very much for your expert advice.
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- Old Man Rock
- Thank you received: 225
I'll give ya a hunskie for it....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- larrycavan
- Visitor
@ Larry... That engine looks like crap... And you call your self an engine builder.... :whistle:
Oh...ok, Cash though
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- APE Jay
- Banned
- Thank you received: 58
thanks again Larry. this is the one?
ACS1100K $49.95
No, the ACS1100K allows you to run the KZ style 3 bold cams in the hy-vo chain J models and GPZs.
We make a sprocket that allows the GPZ cam to be run in the KZ roller chain engine, however, we only make it in a 32 tooth version for motors with the big pin MK11 style cranks.
- racer54
- Thank you received: 114
- larrycavan
- Visitor
- Nelson
- DFIGPZ
- Thank you received: 122
1984 750 Turbo
- APE Jay
- Banned
Jay...why don't you make the sprockets for use with a 15T center KZ1000/Z1 crank? Lots of them out there and would think it would be a good seller. Just curious.
Back in the day, the GPZ cam was sought after by the funnybike guys running KZ motors. It was a perfect turbo cam. Of course all of those guys run the big pin cranks.
That stuff doesn't sell like it used to.
We make a 3 0toorh two bolt sprocket for the Suzuki GS1100/1150. Starts out as the same blank as the Kaw 30T. I will have to check if it would fit the GPZ cam.
