- Thank you received: 225
Can I use newer stock cams to boost my 78 kz1000?
- Old Man Rock
Why stock cams and not some performance cams .365 - .410?
What about the head, valve job, port & polished?
Upgrade the Carbs?
You running points or EI?
Home much "Boost" are you looking for/expecting is the real question... Pending what you're desiring to accomplish, some relatively cheap, others not so cheap...
example, just a little extra zip... EI and some different carbs and a 4-1 exhaust alone might make a difference your looking for.
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Nelson
Restoring and customizing a KZ1000. Click here to read about it.
Plated KTM, DR650, KZ1000, Former MC mechanic (eons ago). 40 yrs. of dirt and street.
- Nelson
Maybe I'm missing it so I'll ask anyways... :blush:
Upgrade the Carbs?
Please read my first post. I have BS34s and a Vance Hines drag pipe, Dyna ignition, all else is stock.
- PLUMMEN
- Thank you received: 104
what do you have for a baffle in that pipe?
- Nelson
The pipe has a homemade baffle, I think it's about 2" in diameter I don't recall. It's straight thru. I've tried running wiht and without, I notice a slight diff at hi rpm, but nothing down low.
- beefsquasher
For your bike, any intake cam from the Z1 to the 1978 KZ1000 will work fine. '79-'80 intake cams will work, just change the sprockets.
Sure guys, it's a small gain, but this guy is after cheap power. It's all labor. Intake cams are a dime a dozen. In fact, I think I have one. PM me and I'll just send it to you, just pay the shipping.
-Dave
1977 KZ1000 Mutt - 1075, Kenny Harmon Cams .400", RS34, Kerker, Dyna S
1997 Honda XR250R
1977 Yamaha XS360
1972 BMW R60/5
- PLUMMEN
the stock ports on a 73-80 head will not flow more air than 28s/29s can supply.
34s on the other hand are basically pushing air through a pipe thats roughly 34mm then trying to force it into a pipe thats closer to 27-28mm with no transition between the two,try running down the sidewalk blind folded with a bunch of people behind you doing the same thing.
now to make it interesting put a step about 5" tall in the same sidewalk and see how that works,first guy trips then it gets really ugly from there! :laugh:
- PLUMMEN
smell what im stepping in? :laugh:
In the words of ronald reagan:mr nelson,tear down that damn wall and build those poor fish a ramp already damn it! :woohoo:
- Nelson
See Dave understands - cheap is the key word here. I enjoy making something from nothing. I'm NOT buying a bunch of expensive performance parts. I just can't justify the expense right now. Just freshening up the stock stuff is pricey enough.
The BS34s were essentially free because I sold the old carbs for the same price... see how I think now? :lol:
- Old Man Rock
<$100, change your sprocket ratios for quicker off the line... +2 up on the rear, -1 on the CC equates to Loss ~ 15-20mph off the top end mph...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- larrycavan
- Visitor
- larrycavan
- Visitor
Okay okay so it's bad idea to fart around with the valve clearance - it's real easy to burn your exhaust valves if you're not careful.
-Dave
