- Thank you received: 3
4 valve head swap?
- hardr0ck68
- Who put the what in the where?
this thread talks about zx900 rods having the same big end as a kz650, and being 4mm longer (depending on what heigth I need they may be useful, maybe not...) and having a 17mm small end.
kzrider.com/index.php?option=com_kunena&...mit=20&limitstart=40
Does anyone know what size the small end on a 1989-90 zx750 is?
It is just hard to get the numbers I need (con-rod length, piston pin sizes
1977 kz650 c1
bought it because I was told it would never run again...I like to prove people wrong.
- kzz1p
- One Test Is Worth A Thousand Expert Opinions!
That's a bit much on the pic's... I don't want to high-jack this thread and make it about my bike - then you throw in Noard's bike? (which is a turbo motor!)
I think we should keep the perspective of the 4V head swap experiment and not shift it onto drag bikes or race motors.
If anybody needs to see pic's of my stuff they should go here:
www.cyclemadness.com/cmforum/index.php?topic=507.0
www.cyclemadness.com/cmforum/index.php?topic=550.0
If you are using your bike as a referance in this thread, can't we see the referance?
Sorry for any HiJacking!
- hardr0ck68
kz650 length (4.213in) 107mm
GSX-R1000 '01-04 small end: 16mm length 111mm
GSX-R1000 '01-04 Stroker Small end: 16mm Length 109mm
GSX-R1000, '05-08 Small end: 15mm Length 111mm
GSX-R1000, '05-08 STROKER small end: 15mm length 109mm
GSX-R1000, '09-10 Small end: 15mm length 112mm
1977 kz650 c1
- Injected
- Thank you received: 543
I don't want anybody to get too distracted with the drag bike - the whole idea of this thread was the 100hp street version of a KZ650... Right?
I just used mine as a reference to show it could be done as a race motor and I did not offer up the pics myself - no harm done, plus the guy who started the thread asked for them anyways...
I would really like to see what dude comes up with.
- hardr0ck68
the gsxr1000 rods are 2mm more narrow on the big end side (kz650 rods are 22mm thick while the gsxr1000 rods are 19.9mm thick)
Unless shimming a rod is a possibility (I have bever heard of it, but how knows :blink: ) the big end is just too thin to use.
1977 kz650 c1
- hardr0ck68
Probably alot of nothing
1977 kz650 c1
- steell
- Injected
I think that 3mm difference is a perfect size for a bushing... anything smaller might be too hard to assemble.
- hardr0ck68
Well the 92' pistons are 3mm larger so the machine shop bored the cylinders to fit the pistons, the 89' rods had to have the small end machined to accept the piston pins from the 92 pistons. The 92' piston pins are slightly larger. Also the underside of the 92' pistons had to be machined as the small end of the 89' rod is slightly wider. The bottom side of the cylinder had to be machined because the distance from the top of the piston to the center of the wrist pin is slightly shorter. As for using the 90' cams they are just 1mm taller meaning the valve lift is more but, I had to reshim the valves. The stock valves are used, I believe the 89' and 90' valves are the same size. There is a little room for larger valves but the cost was more than I was pepared to pay the benefit wasn't worth the exspense. I did port and polish the intake and exhaust ports, and port matched, and I had the head shaved too. By the way after machining the undersides of the pistons they were the same weight as the 89's. Everything was balanced; rods, pistons, pins. Some of the maching I did and other stuff like having the rods resized, boring, head shaved was done by the machine shop. Having all that meat milled out of the cylinders lightened the cylinder by about 10 pounds. I don't have the specifications handy, they're written down somewhere. I ran the engine for a year, it did run very well and I still have it, but I've moved on to another project. I found getting parts for that motor is very difficult especialy water pumps. I am currently putting a 99' zx7 engine in that chassis. Then if money is abundant I would like to bore and stroke and port etc. I built a excell program for determining engine potential and horse power output with various mathematical formula, and the 89' had to much stroke to produce the output I would like and the 96' plus motors are a better bet, also parts are abundant.
1977 kz650 c1
- hardr0ck68
The bad.... the blocks are not even close to the same. He tells me he can do it if I want by cutting the block and spacing 2 and 3 out by about 3/8" then welding up all the stud holes on the upper cases, building up new bosses on the inside of the cases by welding then drilling the new stud holes... he thinks the hardest part will be adding length to the cams. I am now wondering that the cylinder spacing on the kz550 is...
I trust this mans work, enough to throw a let over it and rev it to 12,000 rpm's without a second thought, so if he tells me he can do it, I am sure he can. But what I am trying to work through with him now is, will all this work be worth it? Water cooling and 4 valves is hot shit... but the scale of this mod may just be beyond what I am looking to do.
1977 kz650 c1
- Injected
- larrycavan
- Visitor
It occurs to me that if you want to adapt a 4valve head onto a 650 motor and increase displacement then look at an old 600 Ninja head from 1985. Center cam drive. No idea on spacings but wouldn't be surprised if it was pretty close.
Also 87 zx750, center cam drive.
If that's doable, use the ninja cams and have them hardwelded and ground to suit. Cam sprockets shouldn't be too difficult to adapt from the 650.
Also, I would get some measurements on some old Suzuki GSXR oil cooled 750 heads and see if grafting that might be possible.
Get 750 jugs, bore to 810 and price some custom made 4 valve pistons.
Put the biggest valves in the head you can make work, inject the motor....
JMO
