- Thank you received: 109
Exhaust valve color analysis?
- mark1122
- Keep twisting it
31 Aug 2010 14:06 #395243
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic Exhaust valve color analysis?
did u use oem, or other valve seals? i had a lot of my new seals leak after a new build. i had put in the cheap seals, that came with the gasket kit. i had to replace them all with new, oem seals. all is well now.
after u put some more miles on it, i would do a leak down , and compresion test before u tear it apart. it would be nice to know if u had an oil ring issue .
i dont know if a bad oil ring would show up in thses tests but if there was anything odd about the tests, u could look into it during the tear down.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- 79MKII
- Love Them Kaws!
- Thank you received: 43
31 Aug 2010 17:26 #395260
by 79MKII
The Kaw List:
Replied by 79MKII on topic Exhaust valve color analysis?
I'm not sure what seals were used - I had a shop do the headwork for me. Good idea to test things out before the teardown. It always helps to know what you're looking for. It sure runs great and doesn't show any signs of a problem except for the different appearance when the exhaust is off.
By the way - any theories on why the inside of all 4 exhaust down tubes look the same? They are all carbon flat black looking, not shiny like the valve and exh port.
The Kaw List:
- hocbj23
- Visitor
31 Aug 2010 17:52 #395262
by hocbj23
Replied by hocbj23 on topic Exhaust valve color analysis?
because they are all coated with a layer of unburned hydocarbons?bj
- Old Man Rock
- Thank you received: 225
31 Aug 2010 20:00 #395277
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic Exhaust valve color analysis?
OK, so other then discussions on bad seal concepts, has anything been found out/confirmed on what this goo is?
Oh crap, 79MKII is a smuggler... Black Tar Heroin....:blink:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Motor Head
- Thank you received: 391
01 Sep 2010 06:53 #395348
by Motor Head
Replied by Motor Head on topic Exhaust valve color analysis?
I didn't see where what the exhaust system was. But if the port area is slightly smaller than the header tube, and with the sudden larger diameter causing a loss of velocity with the lower pressure area having the heavies left from rich/ oily combustion sticking there. Plus the cool down as the gases pass over the sudden change in thermal properties of going from the head to a tube.
