PLEASE HELP NO SPEED :(
- steell
yes thats what im saying . after 55-60 u would think by hearing it i was doing 90-100
Well, that's just something you have to get used to. The bike has a small motor and don't produce a bunch of power, so it has to turn high rpm tp get you down the road.
Ear plugs and a helmet help out
I think your bike might do 85 to maybe 90 wide open, and at that speed the tach would probably be on the redline.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
Good call I think... Question is: What RPM is the bike turning @ 50mph?
My KZ1000 turns 2750rpm in top gear @ 60mph, and thats with a bumped up sprocket.
I'm guessing with a tiny bike like that, you're pushing 4000rpm?
It's fairly easy to figure out the bikes top speed/redline in 5th - do the math.
GL.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- dejavoodo41
- Thank you received: 14
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
- at20
1976 kz400
- Kitten Tooth
- Thank you received: 10
GL.
Wait... you can do 2750 at 60 on your KZ1000? how come mines at like 3-4000 RPM at that speed, top gear? WTH:D mines probably geared differently.
1981 Kawasaki KZ1000-K LTD
1983 Suzuki GS300L-D
1982 Suzuki GS300L-Z sold:(
1976 KZ400D3
1973 Z900... I WISH
DO A BARREL ROLL!!
- Thank you received: 2829
well when i get on the highway i hit fifth and around 55-60 mph my tach is only around 6k and the redline dont start till maybe 9k and it just seems like it struggles
Sounds like maybe the clutch is slipping? Have you adjusted it? Definitely get a manual; you really can't own one of these bikes without it. Check eBay for a Kawasaki factory service manual for your year/model. Ed
- at20
1976 kz400
- Thank you received: 2098
- Kidkawie
- I bleed premix
- Thank you received: 245
I was thinking the bike was geared low to make up for lack of power and around town hooligan-ing. compare your sprockets to stock, if you plan on commuting on the highway you might want to change your gearing.
My 900 is at 4000rpm doing 70mph with stock gearing. I'm going to go up one tooth on the front sprocket to bring those R's down a bit.
It's weird, because my 2000 ZX6R absolutely loved the highway. I could literally cruise at 100mph and not feel like I was wringing out the engine.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
- steell
Wow!! I think I'm turning low 4000 somewhere at 60 mph with 17/37 gearing on my 750. Since I have been unable to ride it since last year I'm not saying anything with certainty. That's about to change though!!!
- at20
1976 kz400
- TeK9iNe
GL.
Thats on my 81 CSR 1000, on the 79 LTD 1000 its more like 4k.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
