PLEASE HELP NO SPEED :(
- at20
i just my first bike and its a 1976 kz400 i love my bike but i have a few issues i need to work out. i cleaned my carbs so now its running a lil better so i got that marked off the list but i still cant go any faster then 55 mph without the bike feeling like i need to shift gears. when i get around 45-50mph i hit fifth but i cant go faster then 55. i mean i can twist more but i dont want to mess anything up. it seems like i should be shifting a gear at 55 -60 mph and it would roar down the road. is there something clogged or what. i have an oil leak from my cylinder head covers on both sides. i have the gaskets ordered already. could that be my problem
can someone please help
1976 kz400
- MFolks
- Thank you received: 540
1.Adjusted the valves for proper clearances?
2.Did a compression check?(these engines will run on 120 PSI but 125 is better).
3.Proper heat range and gap on the sparkplugs?
4.Air filter clean?
5.No crud in the gas tank or carb float bowls?
6.Replaced the sparkplug wires and caps? (they get hot and fail).
7.Charging system working?
- at20
1976 kz400
- Thank you received: 2098
hey there fellow bikers
Is engine combusting on both cylinders?
Test while engine is idling by spraying water mist onto exhaust header pipes. Water should sizzle and instantly vaporize. If water rolls down pipe, the cylinder isn't combusting (for whatever reason).
Clutch slipping??
Too much oil in crankcase??
And on and on.
Could be caused by many different things, such as ignition timing, advancer function, compression, valve clearances, defect in ignition system, etc., etc.
Gonna need a manual.
Might be a downloadable manual around here somewhere.
- at20
1976 kz400
- at20
1976 kz400
so since it could be hundreds of things what are a few things easy things i can try to fix it i dont wanna have to put my bike in the shop so i appreciate yall helping me with all this info
The manual available at www.kz400.com/ likely has a "trouble shooting" section which may be helpful. And will also contain loads of pics and detailed info about necessary routine maintenance, such as valve clearance, ignition timing, carb settings, tuning, lubrication, etc. (in addition to the more technical procedures).
What was result of the water mist test?
well i cleaned the carbs so i know its not that . my air filter is clean but i did wanna change to the k&n pod filters. im kinda afraid to mess with the valves cuz if i dont get it right then im S.O.L
Changing to pods will be like do not pass go, do not collect $200, go directly to S.O.L.
- steell
So, are you saying that you could open the throttle more and it will go faster, but you're worried because the engine sounds like it's screaming?
- at20
but for the air pods are u saying that would be a bad idea
yes thats what im saying . after 55-60 u would think by hearing it i was doing 90-100
1976 kz400
