- Thank you received: 2098
KZ750 LTD H2 1981 NEW BUILD FIRST ENGINE START
17 Aug 2010 14:09 #391724
by Patton
Replied by Patton on topic KZ750 LTD H2 1981 PROJECT BIKE - ENGINE START
- angel_uk
- Wildlife Artist and adventurer by any means!
17 Aug 2010 15:55 #391734
by angel_uk
Replied by angel_uk on topic KZ750 LTD H2 1981 PROJECT BIKE - ENGINE START
hi patton
many thanks for the brilliant photos! i've never seen them before!
thanks again for helping me. i'm getting really excited on starting the bike for the first time. i've a friend who is a bike mechanic. he wants me to ride the bike to his shop and then he will safety check and adjust my efforts!
everything works so far. all the pilot lights come on.
the head and taillight and turns all work. they flash.
fingers crossed now!.
i'm just waiting for a warm day to clear coat the gas tank and throttle assembly housing. just been painted by me.
the 2k clear didn't set after 2 months. the paint smudged and this is not good. the tank was stripped of the soft paint and then i'd it powder coated. it looks really good! just needs glossing now!
many thanks for all the techie info. i've cut and pasted in for working through over the next few days.
regards
angie
regards
angie
- MFolks
- Thank you received: 540
17 Aug 2010 16:12 #391736
by MFolks
Replied by MFolks on topic KZ750 LTD H2 1981 PROJECT BIKE - ENGINE START
A forum member "Loudhvx" has been using a replacement for the Kawasaki "IC Igniter" on his 550 for a number of years.
He used off the shelf GM electronic ignition modules. This will only work with bike's having the mechanical igntion advancer.
I'll try to post the website, sometimes it goes, sometimes not so much:
home.comcast.net/~loudgpz/GPZweb/Ignition/GPZgmHEImod.html
Another forum member "Scorly"(Scorley?) from your side of the pond did this modification fairly recently.The problem he had was finding the electrical terminals to fit the modules male pins.
Here's a cross index I made for different manufacturers of the same modules:
GM HEI Ignition Modules (4 Pin)
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
AC DELCO
DM1906 or D1906
WELLS
DR 100
ACCEL
ACC 35361/ACC 35367
PERTRONIX
D2000
CAR QUEST
21040
NAPA ECHLIN
ECH TP45
NIEHOFF
DR 400
BORG WARNER
Select CBE4/CBE22
GM
10482820
Mallory
607
Jegs
555-40600
Moroso
97857
- angel_uk
17 Aug 2010 16:36 #391740
by angel_uk
hi mfolks
a big thank you!
gosh you really know your techie stuff!
i'm getting a bit lost on the tech side, at the moment. one bit at a time, my dad said!
i've now put a tiny bit of engine oil into the sparky holes for an overnight soak!.. i will hand crank the engine tomorrow with a 17mm wrench. by friday my gas tank and throttle will be clear gloss hardened. i might wait until monday next to fire it up! i'm concerned about the clear being hard enough to handle etc.
i want to hear the dinosaur roar mfolks!.. i will be down the road like evil kenevil!
ye ha.. with a big grin on my face!
best wishes
angie
a big thank you!
best wishes
angie
- Kawickrice
- Thank you received: 18
17 Aug 2010 16:54 #391743
by Kawickrice
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
Replied by Kawickrice on topic KZ750 LTD H2 1981 PROJECT BIKE - ENGINE START
When that bike fires up for the first time make sure to have a camera ready. We would all love to see the big giant smile on your face. I smiled for days when mine fired up after a 13 year hiatus.
73 Kawasaki Z1
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
72 Honda CL 175
74 Honda QA 50
Tampa FL
- MFolks
17 Aug 2010 19:27 #391767
by MFolks
There's nothing quite like bringing an old bike back to life! The bike will snort,sputter,clear it's throat and hopefully settle down to a steady rpm.
Have aux cooling on hand in the form of a fan if you're worried about overheating. If you've read forum members "Motorheads" thread about charging system testing, he dicovered the perfect aux cooling system for his bike hanging on his shop wall: A twin 12 volt cooling fans from a vehicle(maybe a Toyota, as I know they use 12 volt fans).
Perhaps a vehicle scrapper would have this for you and your side of the pond.
