- Thank you received: 540
KZ750 LTD H2 1981 NEW BUILD FIRST ENGINE START
- MFolks
Your picture shows the mechanical igniton advancer that will retard/advance the timing as the rpm changes.The "Pulsing" or pickup coils will be on both side of the advancer mounted with the screws shown.
Here's a test procedure I wrote up about checking those pick up coils:
Ohm Checking Pickup(Pulsing) Coils
The pickup coils on the Kawasaki’s with the factory supplied electronic ignition can sometimes fail or become intermittent due to heat and vibration.
1.Trace back from where the pick up coils are mounted,(under a right side CD sized cover) locate and disconnect a small 4 pin connector. Using a multi-meter set on OHMS and range of 2K, check between the BLUE and BLACK wires(#1 and #4 sparkplug wires) for between 360- 540 OHMS.
2.For #2 and #3 sparkplugs the wire colors will be YELLOW and RED, again 360-540 OHMS.
3.If the pickup coils are suspect of failing due to heat, they can be stressed using a hair dryer without the need of the engine running.
4.A replacement set of pickup coils might be obtained from a dealer who serviced the police Kawasaki’s.
5. If replacement pickup coils are not available, your next choice would be to order a Dyna “S†electronic ignition system from www.z1enterprises.com It replaces the IC igniter with a smaller module located where the mechanical ignition advancer was mounted.
6. Checking with Kawasaki.com website has determined that the Pick up(pulsing) coils are available . The pulsing coil # is 59026-1133 and replaces the older # 1002, 1012 which were used from the MKII motors until the 2005 P24.
7.Check the small 4 pin connector that the pickup coils connect to for corrosion/loose pins too.
And the popular ignition coil wiring and ohm testing:
Ignition Coil Primary And Secondary Wiring
Ignition coils on the 80’s Kz1000,Kz1100’s and Gpz1100’s are wired the same, that is as you sit on the bike, the LEFT ignition coil primary(small wires) are two wires, RED and BLACK. The secondary (or sparkplug wires) go to #1 and #4 sparkplugs.
The cylinders are numbered left to right as you sit on the seat; #1,#2,#3, and #4.
For the RIGHT ignition coil, the primary wires, again are two wires, RED and GREEN, with the secondary going to #2 and #3.
The RED wire gets it’s voltage from the run/stop switch on the right handlebar switch pod.
The BLACK and GREEN wires connect to the IC Igniter(if the bike has the Kawasaki supplied electronic ignition) it actually gives the coils their grounds to fire the sparkplugs.
Primary(small wires) side of the coils will read between 1.8 to 3.0 ohms.
Secondary(sparkplug wire ports)side of the coil will read between 10.4K to 15.6K ohms.
To stress the ignition coils, take a hair dryer, heat the coils and see if the ohm readings change from cold to hot . If they do, it’s time to buy new coils.
Keep in mind, the wiring is reversed for the 550’s 650‘s and 750‘s, that is the RIGHT coil primary will be two wires, RED and BLACK with the secondary(sparkplugs) going to #1 and #4.
The LEFT coils primary wiring would be again two wires, RED and GREEN, with the secondary(sparkplugs) going to #2 and #3.
These engines have what is known as a “Wasted Spark†that is, a sparkplug will fire during an exhaust stroke. It does no damage and many other motorcycle engines have this design.
- MFolks
Here in the U.S.,Imperial(American) bolts have their hexheads stamped with markings:
No markings: probably grade 3, relatively soft bolts, not something I use for fasteners.
3 marks 120 degrees apart: grade 5, used for medium strength fastening work.
6 marks,grade 8 higher strength fastener, used in structural,and machine assemblies.
www.unified-eng.com/scitech/bolt/boltmarks.html
www.nutsandbolts.com/v1-bolt-grade-markings.html
Then you have socket head cap screws(sometimes called "Allen Screws or Bolts) and yet another level of strength.
And for most people the MIL-SPEC, or NAS(National Aerospace) fasterner is about as strong as they need unless you're building fighter aircraft or missiles.
Confused?
- JR
- Thank you received: 448
- angel_uk
- Wildlife Artist and adventurer by any means!
thanks for your message. i'm confused about what we need to remove to get at the 17mm nut, the electronic ignition itself?
many thanks
angel in the uk!
- RsvBruno
1981 KZ1000K
1977 KZ650C1
1976 KZ750B
1980 KZ440LTD
- JR
Just remove the outer cover ( noty shown in any pic). The BOLT is the smaller thingy with the "L" on it the centre in your picture. Dont try to turn the engine with that one or you may snap it off. The 17mm NUT is the bigger thingy behind it. Use that to turn the engine over. Put a wrench on it and turn it.
I was surprised at your picture and wondered first why you had taken the pickup coil (electronic ignition)plate off. Then I wondered if your picture showed what you saw when you took off the cover and if indeed your plate with the pickup coils might be missing.... especially since you were calling the advancer the pickup coils.
Did'nt mean to cause any confusion
Sorry
- angel_uk
thank you for your inforation.
please let me explain about this project.
the original engine had 28,000 on the clock. we found a dealer who was selling mint condition parts for a kz750 H2. the photos he sent us were likr new parts. we asked about the engine (just 6,600 miles only) and he said it was parted also and we then had it imported from the USA to the UK. the original engine, minus the electronic ignition, the starter motor was sold on ebay. the photo that we posted on KZR's showes the the empty chamber. you can't buy these electronic ignitions over here. this is now a spare. we also bought the 6,600 engine electronic ignition separetly and just put it back into the newer engine. the dealer sold all the parts one at a time, not a job lot!..
This is the first time that we've stripped, powder coated, chromed, rewired the whole bike etc. it has been a massive learning curve to learn what all the parts are.
i don't even know how to do the bikes timing yet. if the parts that have been parted and then reasembled, would the timing me the same before it was running? the only thing that has happened is the long flight across the pond to the uk!..
the photo we posted is from the older engine, we don't have that now. it's in scotland!...
i hope that by the time the bike is built i will know every parts externally. the harry potter magic that's inside (gears, cogs etc) is left to the experts for tweaking later on!..
i just want to hear this baby start up and roar it's dinosaur head off, like one of the stars from jurrasic park!
please see the attached photo of the USA imported engine!
what a find! $200 plus $500 shipping etc!. i sold my older engine for $600, it was unbelievable! it made my day finding a better engine and selling my oder one!..
just a one off!
many thanks
angel
- angel_uk
- Kawickrice
- Thank you received: 18
73 Kawasaki Z1
07 HD CVO Ultra Classic
82 Suzuki GS 1100
1
Long Gone
75 Suzuki GT550
74 GT 380
79 RD 400 Daytona Special
72 Honda CL 175
74 Honda QA 50
Tampa FL
- Thank you received: 2098
...bought the 6,600 engine electronic ignition separately and just put it back into the newer engine....
Would expect either Dyna-S or Kawasaki.
Dyna-S ignition is commonly paired with Dyna green 3 ohm coils, but might have 4 ohm or even 5 ohm coils.
And the Dyna-S signal wires connect directly to the coils without going through a "black box."
Kawasaki electronic ignition uses lower ohm ignition coils, and also requires an i.c. igniter (black box).
Both Dyna-S and Kawasaki electronic ignitions use the typical advancer unit (centrifugal force on weights against springs) with timing marks for showing the ignition timing.
Dyna-S allows for manual adjustment of ignition timing.
Kawasaki usually allows inspection only -- not adjustment -- of the ignition timing. Inspection alone is valuable for assuring the advancer is properly functioning.
Dyna also has a more elaborate electronic ignition that uses a black box for ignition timing, and which doesn't use the ordinary springs/weights advancer unit.
Here's a comparison of Dyna-S vs Kawasaki.
Maybe yours looks like one or the other of these.
[Click on image to enlarge view.]
- angel_uk
thanks for your message!
it's great chatting to like minded bikers.
all of my mates thought i was crazy to import an engine.
it was a lot of official paperwork. i've always said that to do a job properly you do it to the best of standards.
it has cost me loads of $ for one of your bikes. they're really rare over here. i've imported 3/4 of the bike from the states. the frame, swing arm and other parts have all been chemically stripped and coated!.. new seats. stebal nautilus air horn fitted with a custom (home made) alu bracket that blends nicely with the bike. those horns are a lifesaver. in the uk, the drivers don't see bikers, you've to aware and scan every 5 secs!..
keep in touch buddy!
regards
angel
...here is a photo of the pickup coils
That's the rotor part of Kawasaki electronic ignition which ignition functions in connection with an i.c.igniter (separate black box usually located underneath a side cover).
If needed, good wiring diagrams are available for download here on KZR (see Filebase under KZ Information).
Let us know if any trouble finding the diagram.
