- Thank you received: 1616
Degreeing in stock cams
- loudhvx
Here's more than you ever wanted to know about 550 cams and timing:Hi. I have a 81 kz550. When I was putting new shims in the buckets I may have skipped a tooth (or 3) on the cam sprockets. Damn me for taking the entire tensioner elbow n all out and pressing on the chain! I' m paranoid to turn it over now without putting it back into specs. Is there anything outlined in the manual to do this procedure? I'm no engine builder but learn easily.
Thank you.
home.comcast.net/~loudgpz/GPZweb/CamsKZZ...KZZXZR550500400.html
If the tensioner is out, it should be easy to walk the chain back to where it needs to be. This should be done with very minimal amounts of crank movement. You don't want things colliding. When I do it, I have the cam gears unbolted so they can easily slip off, give slack, and the chain can be walked without removing the cams.
After you walk it, you can put the tensioner back in, but it back in, but don't install the cross wedge or spring. That will have just enough tension to prevent further jumping, but don't turn the crank yet. If you do want to rotate the crank and check timing after two revolutions, put the wedge and spring back in and remember to remove them before installing the valve cover. The tension must not be tight when you install the valve cover.
While rotating the crank with cams and chain installed, I press down on the chain at the top to simulate the cover.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- larrycavan
- Visitor
Thank you.
Actually, taking the tensioner out like that makes it easier to install the cams properly
- CoreyClough
- GPz550 Addiction
- Thank you received: 80
Might be a little overkill, but when I check valve clearances, I now zip tie as in the pictures above, AND mark the cam and chain in different locations. I only remove one cam at a time to change shims, then bolt it back in place before removing the other cam to change shims. The cam tensioner gets loosened about 1/2 inch, but never removed. The zip tie will never allow the cam chain to move from it's location on the cam, and the white paint marks allow rechecking afterwards when it's turned over by hand. If the paint marks line up, afterwards, you're good. I do set the timing to TDC for another refrence mark before marking, and zip-tying.
Overkill? Might be, but it works for me.
Patton wrote:
Here's link to where may download Motorcycle Cam Degreeing for Zombies
Click > kzrider.com/index.php?option=com_docman&...d&gid=451&Itemid=108
Thanks Patton. That link will help me a great deal when I degree my Megacycle Cams to my 615cc engine. I've degreed cams before, and these are adjustable. The pages have been printed, and are awaiting my grubby hands. :laugh: Excellent!!!
'85 GPz550(ZX550-A2)
- mark1122
- Keep twisting it
- Thank you received: 109
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- CoreyClough
- GPz550 Addiction
I find the tricky part to be getting the chain back on the crank properly.
Doh!!! :blink:
- PLUMMEN
- Thank you received: 104
wow !not really my thing but who am i to judge? she might be able to help with your problem though for a price! :ohmy: :huh: :dry: :blink: :blush: :S :kiss: :kiss: :kiss: :kiss: :kiss: :woohoo:I find the tricky part to be getting the chain back on the crank properly.
- Thank you received: 2098
- PLUMMEN
- Becker
- The Doctor Will Rise Again
I don't have personal experience but in world super bikes right now some manufacturers are throwing a fit about the Aprilia bikes having gear driven cams. Apparently throughout the race the other bike's cam chains stretch enough to lose some power towards the end where the gears don't. Other bikes have used gear driven cams but the aprilia bikes come stock with chains and have bosses machined in for gears to be added later for racing applications.
I know that those bikes are high end and 1 degree makes alot more difference, but still. I think it would probably make a difference.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- PLUMMEN
- Motor Head
- Thank you received: 391
Thinking one of the recent Kaw motorcycle models.
Looks complicated.
