- Thank you received: 225
Degreeing in stock cams
- Old Man Rock
Well no shit obi wan konbe.... :whistle: but where speaking of a couple of dgrees on stock cams only, no upgrades out of that....
That's gpoing to cost me folks.... :pinch: :laugh:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- Thank you received: 104
back in the days of superstock racing guys were gaining lots of poer just by paying attention to details like that since major changes werent allowed
- Old Man Rock
Ok, so we all get dialed in at lobe centering for their designs, regardless of OEM stock or performance cams.... but the question is in degreeing to say 105 on stock cams designed for 110 centering...
What do we truly gain?
And I'm asking seriously... a little on the bottom, a little on the top pending which way you go.... How much am I going to lose on the top end to achieve a few umphcas on the bottom end versus some performance cams...
My bet is on the performance cams if you truly want to feel the difference....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Thank you received: 2236
- Old Man Rock
No doubt in this concept... While learning CAM Degreeing, just ask Larry and Plum on how I drove them crazy with questions.... :S :laugh: :laugh: :laugh:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- PLUMMEN
oh my aching head! :woohoo:"Well, some folks just like to optimize what they have. Some folks are just naturally curious about things"...
- Thank you received: 2098
- Jeff.Saunders
I did some rough calculations a few years ago and came up with a badly worn cam chain could retard exhaust cams 3-4 degrees and intake cams 6-7 degrees. I'm not 100% sure my numbers are perfect, but they do show the magnitude of the problem. when I ran my numbers I don't remember if that was at the cam or the crank - if it was at the cam, then the numbers would need to be halved
www.z1enterprises.com
Z1 Ent on Facebook,
- shimvalve
Thank you.
- Old Man Rock
kzrider.com/index.php?option=com_docman&...d&gid=462&Itemid=108
Also, Loudvhx is pretty much our resident KZ550 guru plus electrical... He would definitely get you steered into the right direction....
And BTW, if your off 3 teeth, don't start or ride it....
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- shimvalve
- Kawboy74
- Thank you received: 52
1974 Z1A As original as I could get it
'88 ZX750R braided lines, mostly original
KZ1000 project on the bench
Burlington,Ontario,Canada
