Degreeing in stock cams
13 Aug 2010 08:01 #390593 by oppie501
Degreeing in stock cams was created by oppie501
Anybody degree in there stock cams on kz900/1000 engines? Just curious the effects. I have heard many degree in there stock cams to 105 centerline to give more bottom end torque. Would like to hear others experiences.
13 Aug 2010 08:30 #390598 by BSKZ650
Replied by BSKZ650 on topic Degreeing in stock cams
last time I degreed stock cams, I was suprised at how far off they really were,, I dont remember the number though, bike did run a lot better.
77 ltd1000, current rider
76 kz900, just waiting
13 Aug 2010 12:09 - 13 Aug 2010 12:10 #390666 by Patton
Replied by Patton on topic Degreeing in stock cams
Here's link to where may download Motorcycle Cam Degreeing for Zombies
Click > kzrider.com/index.php?option=com_docman&...d&gid=451&Itemid=108
Good Fortune! :)
Last edit: 13 Aug 2010 12:10 by Patton.
13 Aug 2010 13:35 #390689 by Jeff.Saunders
Replied by Jeff.Saunders on topic Degreeing in stock cams
If you look at the service length specs for the cam chains, then do some math on that, it comes out to roughly 3-4 degrees behind the crank on exhaust, and 6-7 degrees on intake if my calculation is correct.
Those are fairly staggering numbers - esp. when you consider the drag racers are trying to get within fractions of a degree accuracy.
If you ever get a tired old high mileage Z1/KZ, just replacing the cam chain will perk the bike up a fair amount.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
  • Motor Head
13 Aug 2010 14:36 #390692 by Motor Head
Replied by Motor Head on topic Degreeing in stock cams
+1 on the cam chain.
The three bikes I've rescued got fresh cam chains.
All 3 have 26K-30K miles.
13 Aug 2010 15:50 #390697 by oppie501
Replied by oppie501 on topic Degreeing in stock cams
Thanks for the replies guys, I'm actually more interested in weather it is worth changing the lobe center from the stock 110 degrees to say 105 degrees.
  • Motor Head
13 Aug 2010 17:31 #390715 by Motor Head
I think there is a couple of recent posts about that, but do you realize the cost of adjustable gears for your cams? Then how much you will gain? If you really want a change maybe it would be better to select a different cam?
Just some suggestions.
  • Becker
  • The Doctor Will Rise Again
16 Aug 2010 23:39 #391565 by Becker
Replied by Becker on topic Degreeing in stock cams
You don't need to buy new cam gears. You just have to take a rat tail file and enlarge the holes in either direction. It doesn't take much only like an eighth of an inch.
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
  • mark1122
  • Keep twisting it
20 Aug 2010 09:42 #392473 by mark1122
Replied by mark1122 on topic Degreeing in stock cams
try it and let us know. just take some carfull notes about the performance before and after.B)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
20 Aug 2010 16:29 #392564 by BohicaBob
Replied by BohicaBob on topic Degreeing in stock cams
oppie501: Years ago just for giggles, I removed the degreed Yosh R & T cams from my Z1 and replaced them with the stock cams at 102 intake and exhaust centers. As expected, the low-end was nice, making second gear almost the choice from a stop sign take off. Top end power faded before 8,500 however.
Back went in the Yosh R&T cams at 108 intake and exhaust lobe centers for great low end and top end fun.
20 Aug 2010 17:41 #392587 by Old Man Rock
Replied by Old Man Rock on topic Degreeing in stock cams
Been following this and I just can't see what you'd truly gain here without performance cam upgrade degreed to their design/specifications...
Due to cam lobe heights and overlaps, a couple degrees one way or the other, what are you truly gaining...
It's not like it's going to rip you off the seat but for those true motor heads who have tried this.... A little hp increase, a tad more torque on the bottom end....what?
Hell, outside of performance cams, I would think a head job, +1 up on the valves, Port & polish would accomplish more...
Ok, through in the 29-31mm CR carbies....
Oh yeah, Kerker w/1.5" baffle...
Ah hell with it, throw in the performance cam now you've gone this far....
Now you're talkin.... :evil:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
20 Aug 2010 22:18 #392649 by PLUMMEN
Replied by PLUMMEN on topic Degreeing in stock cams
well if youve got a solid older motor you dont want to tear into you might be suprised what a good stiff tune up and cams opening at the right time will do at a stoplight,toss a good header and a set of carbs on there and youve got a fun little daily rider.
some of us have been around long enough to remember how quickly a basically stock motored bike in the right hands can suprise the shit out of a less experianced shmuck on a better bike next to them on the right day,now go back to buffing your spark plugs! :woohoo:
