Degreeing in stock cams
- oppie501
- BSKZ650
- Thank you received: 14
77 ltd1000, current rider
76 kz900, just waiting
- Thank you received: 2098
Click > kzrider.com/index.php?option=com_docman&...d&gid=451&Itemid=108
- Jeff.Saunders
Those are fairly staggering numbers - esp. when you consider the drag racers are trying to get within fractions of a degree accuracy.
If you ever get a tired old high mileage Z1/KZ, just replacing the cam chain will perk the bike up a fair amount.
www.z1enterprises.com
Z1 Ent on Facebook,
- Motor Head
- Thank you received: 391
The three bikes I've rescued got fresh cam chains.
All 3 have 26K-30K miles.
- oppie501
- Motor Head
Just some suggestions.
- Becker
- The Doctor Will Rise Again
78 KZ750B3
79 KZ400 LTD
78 KZ650C2
79 KZ650C3
78 KZ650B2A
80 KZ650F1
80 KZ650E1
81 CB750K Super Sport
- mark1122
- Keep twisting it
- Thank you received: 109
Thanks for the replies guys, I'm actually more interested in weather it is worth changing the lobe center from the stock 110 degrees to say 105 degrees.
try it and let us know. just take some carfull notes about the performance before and after.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BohicaBob
- Thank you received: 35
Back went in the Yosh R&T cams at 108 intake and exhaust lobe centers for great low end and top end fun.
- Old Man Rock
- Thank you received: 225
Due to cam lobe heights and overlaps, a couple degrees one way or the other, what are you truly gaining...
It's not like it's going to rip you off the seat but for those true motor heads who have tried this.... A little hp increase, a tad more torque on the bottom end....what?
Hell, outside of performance cams, I would think a head job, +1 up on the valves, Port & polish would accomplish more...
Ok, through in the 29-31mm CR carbies....
Oh yeah, Kerker w/1.5" baffle...
Ah hell with it, throw in the performance cam now you've gone this far....
Now you're talkin.... :evil:
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- PLUMMEN
- Thank you received: 104
well if youve got a solid older motor you dont want to tear into you might be suprised what a good stiff tune up and cams opening at the right time will do at a stoplight,toss a good header and a set of carbs on there and youve got a fun little daily rider.Been following this and I just can't see what you'd truly gain here without performance cam upgrade degreed to their design/specifications...
some of us have been around long enough to remember how quickly a basically stock motored bike in the right hands can suprise the shit out of a less experianced shmuck on a better bike next to them on the right day,now go back to buffing your spark plugs! :woohoo:
