Bikes kickstart won't move
  • TerryK
  • TerryK's Avatar
Re: Bikes kickstart won't move
03 Aug 2010 07:47
#387879
Cookie1893 wrote:
This motor has potential. So far u had it 2 days and I couldn't even get it to turn over when I brought it home and now it's starting to turn and the kick starter is starting to work. I say with a little work I can getting running with no problem. But I will keep you posted on my build and how the motor is coming along.
You have to understand that if the rings and cylinder walls are rusted bad enough to stick the engine that once you get it free all that rust just doesn't disappear, it will continue to do damage to the engine once it's running. Also keep in mind that rust is not a surface build up, it's the oxidization of steel which means it's removing material from the rings, cylinder walls etc. Also keep in mind that dissimilar metals like steel/aluminum will react to each other over long periods of time, especially when moisture is introduced.
Do yourself a favor and at least pull the covers off and inspect for water damage and look inside the spark plug holes for the same. If you see rust and a powdery white substance then you have trouble. Maybe take some pics and post them here.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
  • Cookie1893
  • Cookie1893's Avatar Topic Author
  • Alex Cook
03 Aug 2010 11:39
#387911
It had carbs and exhaust on it the whole time while it was sitting outside the two months. And I will send pics. Tonight I'm going to take the side covers off and inspect for water. Also i already have the spark plugs off and there is no rust down there.
1977 KZ-650 total motor rebuild project
Hopefully after I get the girl running she will fit on the back of a go-cart.... Betcha never saw that one comin!
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
03 Aug 2010 12:33 - 03 Aug 2010 12:34
#387914
I think that engine would run just fine. My Z1 was sitting for 14 years, rode a couple months, then sat another 12 and fired right up.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
Last edit: 03 Aug 2010 12:34 by Kidkawie.
  • Cookie1893
  • Alex Cook
03 Aug 2010 14:24
#387927
I have a feeling it will fire right up too. All I need is carbs and a good cleaning and it should fire up no problem.
  • Cookie1893
  • Alex Cook
03 Aug 2010 14:59
#387940
here are the pictures. i had to hurry up and take them because a rain was coming and i had to put a trash bag over the motor but tell me if this is good or bad. i also have a picture with the stator cover off. more will be posted soon.
-Cheers,
Alex
  • Cookie1893
  • Alex Cook
03 Aug 2010 15:01
#387941
other side...
  • Cookie1893
  • Alex Cook
03 Aug 2010 15:02
#387943
this is with the cover off. tell me if it looks okay. thanks.
  • KZ250LTD
  • KZ250LTD's Avatar
03 Aug 2010 16:55
#387968
That tharr be the points cover, stator cover is on the other side of the motor. Near the front.
As has been said, a manual is invaluable, even if you don't have the whole bike!
79 KZ1000ST
Past:
Many.
  • Cookie1893
  • Alex Cook
03 Aug 2010 17:39
#387979
Oh okay I didn't know exactly what that cover was called. And I called the library and they said they will buy the clymers manual to the kz-650
  • TerryK
  • TerryK's Avatar
03 Aug 2010 18:12
#387985
OK, so it looks pretty clean on the outside, but you STILL have a problem. The engine is tight and to merely put fuel in it and fire it up is mechanical suicide. You really need to find out what the problem is. Really.
Seriously.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
  • Cookie1893
  • Alex Cook
03 Aug 2010 18:27
#387991
Yeah we put oil down the spark plug holes and it's still not spinning very good. Good thing I'm in auto shop this year. I'll have to do a complete tear down looks like. I hope it's crankshaft isn't bent. But I did look down the spark plug holes and it's all filled with white powder. Corrosion? I don't know but looks like I have some work cut out for me.
  • TerryK
  • TerryK's Avatar
03 Aug 2010 22:57 - 04 Aug 2010 07:59
#388033
I guess you didn't read my other post. Aluminum corrosion can damage engine parts and once it gets going it advances very quickly. Inside an engine it's mainly caused by water/moisture reacting with chemicals that are the result of combustion. This creates very caustic acids that literally eat pistons and other aluminum parts. If you have a lot of if chances are your pistons and maybe even your cylinder head are damaged.
Some examples of aluminum corrosion.
1977 KZ1000
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
Last edit: 04 Aug 2010 07:59 by TerryK.
