- Thank you received: 103
re-use a torqued head gasket?
- roy-b-boy-b
Just a piece of history thrown in. Roy
- bountyhunter
- Thank you received: 337
Of course, the history books claim Dugout Doug was ordered to leave...... at any rate, he was later awarded the congressional medal of honor for a campaign that ended with him running like a jack rabbit. Some of us found that a little hard to take. I assume he had his ears plugged to not hear the tens of thousands at Arlington rolling over in their graves when they pinned the CMH on....
- blue75kz900
Just put the torque wrench on and torque until it clicks again. Or loosen the bolt a half a turn and re-torque to spec.
Mine torques to 30 ft-lbs, retorque doesn't change this value, correct?
Thanks.
Blue 1975 KZ900
Gold 1970 Chevy Nova 427...Bike killer
- bountyhunter
Same value. I do a progressive torque. I set the wrench to 50% of the full value and torque all bolts. Then go to 75% and torque all bolts. Set wrench to 100% spec and final torque. Run the engine to get it full hot (at least 30 minutes) and retorque to 100% spec.So what is the correct process for re-torqueing a head gasket after a new replacement?
Thanks.
- blue75kz900
SO I should just set the torque wrench to 30 ft-lbs and torque them?
I did the progressive torque when I tightened the head the first time.
Thanks.
Blue 1975 KZ900
- zed1015
- Thank you received: 1559
Don't loosen before re-torquing.
All you really needed to do was get the motor hot then leave overnight to cool then re-torque the next day (This is all what the manufacturers do).
Then after 100 miles i give them another check just to be on the safe side but i've never found them to have loosened at the 100 mile check.
After all you don't see the factorys running up 100's of miles on each new bike they churn out do you.
- mark1122
- Keep twisting it
- Thank you received: 109
So, I've run the bike for 250 miles without re-torqueing the heads.
Thanks.
Yes.
i personally take 1 nut off at a time and put Permatex engine silicone sealant under it, then retorque it following the proper sequince.
many guys just retorque, without backing it off.
i just feel that i dont want oil coming up around the nuts, so i seal them, and the sealant acts as a lubricant to aid in the torque. The copper washers are supposed to seal it but they have been reused many times. Overkill? probably. but thats what i do.
Good luck.
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- Old Man Rock
- Thank you received: 225
Here's what Larry & Plum taught me...
Cold engine, don't back off and as others mentioned, follow spec'd sequence...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- bountyhunter
Maybe they should. On my new '79 KZ750 a short time after I bought it, one of the outer head bolts got so loose it was almost finger tight before I noticed it. The 500 mile service on mine was changing oil, checking valves and retorqueing the head.After all you don't see the factorys running up 100's of miles on each new bike they churn out do you.
- PLUMMEN
- Thank you received: 104
they should of turned him over to the americans he left behind when he returned!McAruthur escaped the Phillipines on a PT boat that had been rebuilt using the old gaskets.
- trianglelaguna
- Thank you received: 235
re-use it and torque it with a garage sale wrench.....
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- bountyhunter
