re-use a torqued head gasket?
- thadley55
- TWO WEEKS!!!(Money Pit the movie)
1975 XL125 Honda first bike
1993? VTR 250 Honda gone
1983 LTD 440 Yammy gone
1988 CBR 600 Honda gladly gone!!
1976 KZ900 daily driver
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- mark1122
- Keep twisting it
- Thank you received: 109
after a couple of heat cycles, retorque the head. then again after about 1000 miles. the worst thing that can happen is an oil or compression leak. it is normal to have to retoque anyways.
Good luck:)
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- thadley55
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- thadley55
- mark1122
- Keep twisting it
if u dont notice any leaks,or compresion dif between cylinders (check with a compresion guage) dont change the gasket, it is obviously working.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- zed1015
- Thank you received: 1559
Can't do any damage to the motor it'll just run sh*t if it leaks etc.
Have done a similar thing myself with a fibre gasket, That was EIGHT years ago and its still running ok now.
Only gonna cost you a new gasket and some time if it don't work so don't throw money away unless you HAVE to.
- Mark Wing
- Thank you received: 22
Mark
Yorba Linda Cal.
- bountyhunter
- Thank you received: 337
I ran my head gasket about 200 miles then had to pull the top off. I used copper spray and reused the gasket. Been working fine for three years now.Okey Dokey! I will order a new gasket, but It won't hurt to run it long enough to break in the new rings?
- Tony
- Thank you received: 13
- Old Man Rock
- Thank you received: 225
Outside 1%, after initial start up she leaks and re-torquing doesn't work... pull the top off and get another gasket...
Hell, only a Saturday job to swap out and put back together....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
