- Thank you received: 1
1075 street motor
- Ituen
- Rider
1982 KZ750 E
Kawasaki Rider
- PLUMMEN
- Thank you received: 104
- keith1
- Thank you received: 2
more than enough to get the job done im sure depending on chassis and rider
richard would master it..'cause he is cool!!......
- will61310
- Thank you received: 6
...1980 LTD 1000...
- keith1
Didnt realize you were a fan of the "Richard"
ive seen the light....he is cool without a doubt....i think we should all remind him that he is cool......
- will61310
...1980 LTD 1000...
- keith1
I will take a pass and keep my opinions of him to myself...
check your pm s .....
- larrycavan
- Visitor
I agree Someday, when we're all deserving enough, we can all "Be Like Dick". That's my goal anyway :woohoo:
- trianglelaguna
- Thank you received: 235
den all dem fags is gonna wanna fight wiff me....
(youtube)
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- larrycavan
- Visitor
How much horsepower is it going to put to the pavement?
With his little 26mm carbs and the stock cams, probably in the 85 range. With the J intake valves and the street cut ports, it should have nice midrange torque and very crisp throttle response.
Add the .365 lift cams and some 29's, then you start getting up around 100.
It's built for the way the guy really rides the bike
- porchev914
- Thank you received: 19
FRANKEN Z!
- larrycavan
- Visitor
If you're going to replace the valves on a 1st generation head, is it worth it to use J model sized valves Larry?
Yes, I think so. I use the J valves because they're shorter than a KZ valve. You need to sink the valves when you go OS like that. This way you have room to work with a stock base circle cam.
