Won't Idle
Re: Re kz750 resurrection
28 Apr 2010 12:54Can't proceed without knowing model YEAR of the bike in question.
So Fess Up - - - what year is it??
- ndfez
28 Apr 2010 13:16
ndfez wrote:
ndfez wrote:
The ball bearing likely remained in place inside the push rod passageway, and didn't fall out.
Which type adjuster is on the bike at hand (i.e., screw type or ball-and-ramp type)??
The two different types usually work in opposite directions when turning to set the desired gap.
I went to the site an would not give me any info on my bike.I didn't see any ball bearing when I pulled it out would it be in the motor or what?
ndfez wrote:
I figured it out thanks.The web site at least.
- ndfez
28 Apr 2010 14:16
Screw type,I think I found the problem,the spring for the clutch cable looks to be stretched out a little to much,so bought a new one to see if that is the problem.I got my shifter to go into first without engaging the clutch handle an neutral,but when I got to put it in 2nd an so on it won't my rear tire moves still like it is in nuetral why?
28 Apr 2010 15:59
ndfez wrote:
That's normal.
When the bike gets rolling, it will shift into 2nd, etc.
...got my shifter to go into first without engaging the clutch handle an neutral,but when I got to put it in 2nd an so on it won't my rear tire moves still like it is in neutral why?
That's normal.
28 Apr 2010 16:13
If uncertain about the bike's year of manufacture, look at the label on the right side of the frame neck under the steering head.
Should also be on the ownership papers that came with the bike.
28 Apr 2010 17:18
ndfez wrote:
Imo, it's not the spring.
Cable itself might be partially frozen or internally frayed, or just need oiling. The internal braided cable is supposed to move easily and freely back and forth inside the sheath.
If needed, new clutch cables are available at Z1E and are relatively inexpensive.
Screw type,I think I found the problem,the spring for the clutch cable looks to be stretched out a little to much,so bought a new one to see if that is the problem....
- ndfez
28 Apr 2010 18:37
I have a 1981 KZ750,thought I had the screw type clutch guess not,the ball an ramp style,excuse me new to this in every which way.K I will look at everything better an try the things ya'll have givin me thanks
28 Apr 2010 19:13 - 29 Apr 2010 07:14
ndfez wrote:
Clutch Push Rod Adjustment. Here's how:
Would first lubricate clutch cable, or replace it if necessary.
With bike fully assembled ---
Put maximum slack in clutch cable (adjusters at handlebar and at mid-cable).
Remove access cover to pushrod adjuster screw and locknut.
Loosen locknut.
Turn screw counterclockwise until lightly seated.
Turn screw clockwise 3/8" turn.
Tighten locknut (just snug, don't over-tighten)
Replace access cover.
Adjust clutch cable slack, using both adjusters at handlebar and at mid-cable.
Should be able to squeeze hand-lever about 1/8" very easily before lever gets harder to squeeze as the clutch starts to disengage (compressing clutch springs).
If results are unsuccessful, I may have the screw-turning reversed, as am just guessing without the FSM (Factory Service Manual).
So repeat the process (as used with screw type style):
... Loosen locknut.
Turn screw clockwise until lightly seated.
Turn screw counterclockwise 3/8" turn.
Tighten locknut....
Loosen locknut.
... Loosen locknut.
Tighten locknut....
Last edit: 29 Apr 2010 07:14 by Patton.
