Won't Idle
  • KZ1000CSRman
  • KZ1000CSRman's Avatar
Re: Won't Idle
04 May 2010 13:54
#365496
jswag5 wrote:
too rich or getting oil in the cylinders.
can somebody take a picture and load it here for how the pilot adjustment get get it leaner?
'82 KZ1000 CSR
  • ndfez
  • ndfez's Avatar Topic Author
Re: Won't Idle
04 May 2010 14:49
#365513
What do you set your meter on to get the correct ohms?
  • Sircraigery
  • Sircraigery's Avatar
Re: Won't Idle
04 May 2010 15:37
#365520
Set the dial to ohms, and make sure your positive leads is plugged in the proper terminal for ohms.
The positive lead terminal changes for reading either ohms/voltage or currents. You probably already knew how to use a multi meter, just saying make sure it's set up right.
  • ndfez
Re: Won't Idle
23 May 2010 13:52
#370220
Okay now my bike starts fine,but after a few seconds of idling it starts to rev higher an higher until I shut the bike off why is this?
Re: Won't Idle
23 May 2010 14:36 - 23 May 2010 14:37
#370246
Would suspect air leak and/or sticking advancer.
Maybe too lean pilot circuit.
Good Fortune! :)
Last edit: 23 May 2010 14:37 by Patton.
