Won't Idle
- ndfez
- otakar
Re: Won't Idle
23 Apr 2010 05:40
Need more information about your bike. " Hay doctor, my pet wont let me touch them, can you tell me what is wrong with them?" Get the idea?
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- TeK9iNe
- What did you do!?!
Re: Won't Idle
23 Apr 2010 15:57
:laugh: :laugh: :laugh:
Anyways...
The idle adjust knob is attached to the carbs/rack.
It is usually about a 3/4 inch large thumb style screw that you can turn in/out about maybe 8-10 times before it stops or falls out. Turn it in to watch the idle and carb slides increase/lift.
Some have it on the bottom back side. Some on the bottom front... some on the top right. But they all look reletively the same.
GL
Anyways...
GL
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- Jodyb17
Re: Won't Idle
23 Apr 2010 17:13
Back when my bike was running it seemed like I always had to fool with this screw to get it to idle correctly.
Is this a set it and forget it screw, or does it need regular attention by design?
1977 KZ 650 C
- JR
Re: Won't Idle
23 Apr 2010 18:39 - 23 Apr 2010 18:40
ndfez wrote:
If your 750 is an 80 or 81 four cylinder then your idle knob is between carbs 2 nd 3 underneath and pointing down and back. Dont know about twins or later models.
.............and it should be set when well warmed up and forget
MY KZ750 won't idle any ideas?Were is the idle knob adjuster located at?
Last edit: 23 Apr 2010 18:40 by JR.
- ndfez
Re: Won't Idle
25 Apr 2010 07:04
Thanks for all the help got the 750 to idle,now number 2 an 4 sparkplugs are getting burned black why is this?
- jswag5
- whats the big deal about harley, i prefer 4 cyls!!
Re: Won't Idle
25 Apr 2010 07:32
too rich or getting oil in the cylinders.
82 kz1000p
83 yammie xj750mk bobber
78 honda cx500 standard cafe
RECENT 81 honda goldwing(barn fresh with 15000 on the clock)
if you cant fix it with a hammer and duct tape, get a bigger hammer and more duct tape!!
- ndfez
Re: Won't Idle
25 Apr 2010 08:05
Oil in the cylinders,is this bad gasket?Is there a adjuster for the oil?
Re: Won't Idle
25 Apr 2010 09:07 - 25 Apr 2010 09:14
ndfez wrote:
jswag5 wrote:
Possible causes might also include:
-- Weak spark;
-- Wrong size spark plug;
-- Insufficient compression.
-- Weak spark;
Last edit: 25 Apr 2010 09:14 by Patton.
- polkat
Re: Won't Idle
25 Apr 2010 11:22 - 25 Apr 2010 11:26
Is the black stuff on the plugs dry and fluffy or wet and oily? What do you smell on them? You said you see oil in the cylinders? Bad rings or worn valve seals/guides/stems. But considering you've been adjusting for idle problems, those cylinders might be running rich.
Last edit: 25 Apr 2010 11:26 by polkat.
