- Thank you received: 7
shifter shaft broke
- riverroad
- 1980 1000LTD B4
14 Apr 2010 05:23 #360563
by riverroad
shifter shaft broke was created by riverroad
Dblhdr, one of our members, has just informed me he was on his way to work and he broke his shifter shaft. It is a 1979 police model with the heal toe shifter. He says it's the shaft that comes directly out of the engine.
What all is involved with replacing this thing?
Possible to replace without splitting the cases? (pray pray pray).
I've heard of the shifter breaking, but never the shaft coming from the engine.
- patmann
- Thank you received: 6
14 Apr 2010 07:23 - 14 Apr 2010 07:23 #360581
by patmann
1974 900 Z1 modified to look like a LTD , some engine mods. But I still have all the original parts.
1977 1000 project bike
1972 H1 project bike
If pro is opposite of con, then what is the opposite of progress?
Replied by patmann on topic shifter shaft broke
IF and I do say IF it's like my old Z1, the shaft does NOT go into the cases. As I just found out this week, see my posting on broken shifter return spring.
It might be a total different animal too.
A real simple item to get to also. Took me about ten minutes maybe. And that included fighting 37 years of grim and stuck screws.
Pat
Pat
Last edit: 14 Apr 2010 07:23 by patmann.
- riverroad
- 1980 1000LTD B4
14 Apr 2010 08:16 #360594
by riverroad
Replied by riverroad on topic shifter shaft broke
Thanks Patmann. That thread gives us a little encouragement.
We have a memorial day weekend ride planned and hes at near panic already. As a matter of fact, he's now paniced enough to buy a Concourse 1400. :laugh:
All fine and dandy, but I think another shaft might be cheaper.
- patmann
14 Apr 2010 12:36 #360643
by patmann
Wondering if it's broken @ a place that's weldable??
Weld it for now, and and look for a used new one??
- Thank you received: 797
14 Apr 2010 14:06 #360653
by 531blackbanshee
Replied by 531blackbanshee on topic shifter shaft broke
pretty sure that you just pull the countershaft sprocket and then pull the cover behind the c/s sprocket and it is right there with the pauls(hooks) on it.a lil short feller.no step for a stepper.
14 Apr 2010 14:09 - 14 Apr 2010 14:18 #360654
by 531blackbanshee
check the link.
www.babbittsonline.com/pages/parts/viewbybrand/default.aspx
you guys got this no sweat.you may wait just a lil bit and let him get the conny so you can borrow it for fixing his cop bike. :laugh:
p.s. you will have to fill in the bike info then go to gear change mechanism and you can see the parts.after that you can go to engine covers and you can see the cover that you have to remove.hth.
Last edit: 14 Apr 2010 14:18 by 531blackbanshee.
- ltdrider
- Thank you received: 17
14 Apr 2010 14:44 - 14 Apr 2010 14:48 #360658
by ltdrider
'76 KZ900 LTD (Blaze)
'96 Voyager XII (Dark Star)
Greensboro, NC
Replied by ltdrider on topic shifter shaft broke
I have a .pdf excerpt from the Service Manual showing the external shift mechanism, but don't know how to post it. It's about 8 meg.
Tim
Tim
Greensboro, NC
Last edit: 14 Apr 2010 14:48 by ltdrider.
- timebomb33
- Thank you received: 10
14 Apr 2010 17:10 #360680
by timebomb33
I THINK MY POWERBAND BROKE
Replied by timebomb33 on topic shifter shaft broke
very simple job shouldn't take much time at all he will be up and riding very soon.
- dblhdr
- Thank you received: 2
14 Apr 2010 17:40 #360690
by dblhdr
1981 KZ1000 Police Special coverted for civilian use with passenger seat, custom luggage rack, and paint. Daily rider.
2006 Harley Davidson Road King FLHR1
Replied by dblhdr on topic shifter shaft broke
Here's the broken shaft
powers edge has a new one for 70 bucks plus shipping.
I haven't looked for a used one yet.
- dblhdr
15 Apr 2010 19:37 - 15 Apr 2010 19:46 #360977
by dblhdr
I decided to take a look under the chain cover before I ordered the parts I would neeed. I think that I will order a new clutch cable when I get my parts. This one looks like it could be original. I scraped thirty years of gunk out from under the sprocket cover.. I've never pulled the sprocket before. Is there anything I need to know before I start taking it apart? do I need to loosen the chain before I take off the sprocket? :blink: Should I get some help over here?
Last edit: 15 Apr 2010 19:46 by dblhdr.
- dblhdr
15 Apr 2010 19:49 #360981
by dblhdr
- MFolks
- Thank you received: 540
15 Apr 2010 20:32 #360990
by MFolks
Replied by MFolks on topic shifter shaft broke
Keep the chain on to help loosen the nut on the sprocket.you might need someone to stand on the rear brake for added resistance.
On some Kawasaki's, a metal washer had edges folded over to lock the engine(or countershaft sprocket) to the output shaft.A cold chisel and hammer will straighten out the bent tabs.
I'm probably wrong, but I think the nut is at least 22mm. I used a 1/2" long breaker bar to get my bike's sprocket nut off when I changed chain and sprockets.
While you're in there,carefully pull out the clutch push rod,clean off the accumulated chain lube,clean and re-lube the push rod mechanism.
The three yellow wires seen in the picture are the ones from the alternator stator, check the "Bullet" connectors on them for over heating and corrosion.
