Motor Rebuild Time
- XL777
Pistons look ok, cly look good no gouging or scoring. I have yet to do measurements
The head and valve need work definitely need valve seals.
Im tearing into the bottom end hopefully this weekend.
Any tricks on holding the drive sprocket still I don't have the "special tool" or the ability to make one.
I'll post pics tonight.
Here are my plans hopefully
APE 1075 kit + bore and sleeves
new valves
adj cams
Port/polish head
New cam chain
clean up bottom end and service transmission
When I get this done it should haul ass! When will be the question and how much haha
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
- Thank you received: 2098
6 more bolts and the motor is out...Any tricks on holding the drive sprocket still I don't have the "special tool" or the ability to make one....
If the question is about removing the countershaft sprocket and needing to hold it in position while unscrewing the nut, it's likely easier to accomplish before the engine is removed.
Otherwise, with the engine already removed, and without the special tool, some rigging with length of chain, plus an air impact wrench, and some heat, may be necessary.
- XL777
Monday I'm taking it to get solvent washed
Then soda blasted. Any idea where you can find bulk soda in Canada?
Check out the pics
s276.photobucket.com/albums/kk12/XL777/KZ%20Project/
Looks like my one of my local shops has exp. with the KZ. One guy used to race them and claims he has some performance parts.
Ported and polished head with stronger springs. 1075 cyl. and new 12:1 comp. pistons with cams. Not sure if he will part with them but any idea what this stuff would be worth used? I know its new costs.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- timebomb33
- Thank you received: 10
I THINK MY POWERBAND BROKE
- XL777
The shop is retro cycle in Red Deer. Nice guys very welcoming not like the local kawi shop bunch of jerks.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- keith1
- bountyhunter
- Thank you received: 337
Scotchbrite pads and elbow grease.Also how do you get 34 yrs of carbon build up off the pistons, head, and valves?
- XL777
Head sent in for complete rebuild $800
Cylinder sent to be bored out $400
New 1045 pistons $550
misc parts $400
Getting it all back together and running priceless
One question
I had to go with one size bigger pistons due to the bore. My mech recommended going with the 1045 rather then the 1075 since it doesn't add much more in performance and if you ever needed a bore out in the future you would need a new block.
What do you think? The 1075 seems to be the more favored option from my research any reasons why?
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- Old Man Rock
- Thank you received: 225
Unless of course yours are all gouged up or something...
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- XL777
Project started out as just rings HA! Full top end rebuild, completely rebuilt head, 1045 bore, new pistons, is the final result should be sweet :)In the process I had the covers bead blasted and the block and head looks sharp.
I have posted some pictures to my photo bucket take a look. All that is left is valve adjustment and final odds and sods. Hopefully by week end I will get to fire it all up YEAH! Then the real fun begins tuning and breaking it all in.
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- saxjonz
- KawboyZ
- Thank you received: 76
XL777 wrote:
Sorry I have not kept this post up to date. Busy summer family, work, etc. However, I am getting close to having the bike back up and running.
79 LTD B3
