- Thank you received: 391
Motor Rebuild Time
- Motor Head
- keith1
- Thank you received: 2
Cam chain a good Idea, but you don't have to remove the motor and split the cases. They make Master links for a reason. I did all my own head work, and rings/ honing/ cam chain etc. All in frame, and an 82 1000 4 cyl. New valves for the exhaust was the most expensive, $27 each.
a few people poo-poo the splitting cam chain and re-join deal....not taking anything away from these folks and their
many years of experience, but in a street re-build, this can be a succesfull endeavour...the key is making sure the staking of the pins is as good as ,if not better than the factory ones ...i ran my first cam chain re-link through the wringer and it held up......i now run a tsubaki hd with a master -link and so far all is fine......the important part is staking it right.......just my .02......
- rt green
- Motor Head
- keith1
are those cam chains marked?
nope, just make sure you break chain on the correct two pins...dont ask how i know that....:laugh:
- 9am53
- homebrew, and some bbq
So all you did to the motor was new rings?
Basically. I got new rings and cams, soda blasted the head because it was nasty, lapped the valves, and new valve seals. I wasn't going for a major overhaul...if you just want to do top end maintenance like me it doesn't have to be too expensive. My issue is that I got on a roll and couldn't stop... all I initially wanted to do was change the head gasket and valve adjustment. :blink:
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- XL777
2012 Triumph Bonneville SE black
1978 KZ1000 B2 LTD
Fresh top end rebuild
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
It is easier to say what I haven't replaced then what I have.
I must love this cruel mistress since she hates me
- XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- bountyhunter
- Thank you received: 337
It's buildup from the leak down from leaky valve seals. been there, seen that....Well I have torn it down to the head base and it is not looking pretty. A lot of oil through 1/4 valves and on top of the pistons.
- XL777
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- XL777
Has any one done this and if so what else needs to be added and replaced to make the kit work
1978 KZ1000 B2 LTD
Rebuilt head
Wiseco 1015 pistons
Dyna s
Green Dyna coils
Wired george mod
- Thank you received: 2098
Fun... Another issue is how hard is it to have your spark plug re thread? Somehow I cross threaded it putting it back in last year ?????.... It was an SOB to get out and sure enough the threads are messed up on cyl 3.
If standard tap won't fit beginning at the deep end due to space limitations, there's a "reverse tap" tool available that inserts from the outside and taps from the bottom where the threads may still be okay. Using the reverse tap doesn't require removal of the valve cover or head from the engine. Simply remove the spark plug and start using the reverse tap.
Also known as a "back tap" tool.
