Reasonable Dyno results?
  • Mkosharkii
  • Mkosharkii's Avatar Topic Author
25 Mar 2010 23:34
#356232
Just got back from a 6 month deployment on a submarine and finally have some time on my hands.
Right before I deployed, I had the bike dynoed at a local shop. I'll get around to posting the scans, but the peak horsepower was 90 on the dot. My bike is a 79 1000 LTD with the following mods: 10.25/1 1075cc, Mikuni VM29's w/ pods, APE .410 cams and springs, and a Kerker 4-1 w/ baffle. From your guys experience, does 90hp at the wheel seem right?
Thanks in advance for the advice.
  • will61310
  • will61310's Avatar
Re: Reasonable Dyno results?
25 Mar 2010 23:58
#356234
I had an 1166 GPZ 1100 with headwork and 36 mm flatslides and a kerker that only did 110,so that sound about right to me..
...1980 LTD 1000...
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
26 Mar 2010 02:14
#356241
yep...90 at the RW sounds good.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • larrycavan
  • larrycavan's Avatar
26 Mar 2010 03:58
#356244
90 is a realistic number with those mods. Stock would have been about 65.
  • trianglelaguna
  • trianglelaguna's Avatar
26 Mar 2010 04:48
#356253
funny ...just reading up on the bike i picked up and kawi lists 92 stock....to bad...sounded too good to be true.........
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
  • Old Man Rock
  • Old Man Rock's Avatar
26 Mar 2010 05:28
#356267
Low to mid 90's yup, sounds about right....
"just reading up on the bike i picked up and kawi lists 92 stock....to bad...sounded too good to be true"...
Rear wheel or crankshaft numbers...;)
Larry and I spoke of this many moons ago pre-engine build and expected numbers... As in the example of the front of our service manuals gives torque and HP graphs.... The numbers for a stock 900 or ~ 80ish.... Those are Crankshaft numbers, not rear wheel....
Out of curiosity, what torque numbers came out of your Dyno run?
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • otakar
  • otakar's Avatar
26 Mar 2010 06:24
#356280
You can change the HP#s just by changing your rear sprocket. As OMR said, it is the torque #s that tell the story.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
  • otakar
  • otakar's Avatar
26 Mar 2010 06:26
#356281
If you put a stock Harley 1200 on a dyno, t will read about 45hp but the torque will be off the chart.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
  • Jack
  • Jack's Avatar
26 Mar 2010 06:49
#356286
They left out MEASURED AT THE CRANK. RWHP will be less every time...
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • otakar
  • otakar's Avatar
26 Mar 2010 07:04 - 26 Mar 2010 08:17
#356288
My 1150 "J" motor with .420 intake and .410 exhaust heavily ported 84 GPZ head is geared for top end I am putting a 40/18 (2.28:1) final drive ratio on it. A properly geared 750 would be able to jump away from it in a hole shot. But once we start to get any speed I will have the advantage all the way. Standard rear ratios for Kawasaki was 39/15 (2.6:1) for cruisers and 41/15 (2.73:1) for hi-performance bikes. some drag racers use 46/14 (3.29:1)
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 26 Mar 2010 08:17 by otakar.
  • larrycavan
26 Mar 2010 16:52
#356371
900 / 1000 KZ's were 35/15 while LTD's were 33/15.
39/15 gearing on a KZ 1000 is for wheelies... :laugh:
Your gearing is for traveling very fast with a built motor like that. I keep wishing I had a 6 speed trans in my bike... :)
  • turboguzzi
  • turboguzzi's Avatar
26 Mar 2010 17:15
#356373
have to disagree, hp is purely a function of the work the engine performs in a given time, its unrelated to gearing.
In any case, 90 sounds good to me too.
TG
