Cleaning carbon from combustion chambers?
- Old Man Rock
Re: Cleaning carbon from combustion chambers?
21 Feb 2010 06:19
Ok, question of the morning that I'm sure will turn into a debate around here... :whistle:
As much as I like the steam bath solution, not sure about soaking them in the sink due to the following....
Unless your planning on removing & replacing the valves, guides, seals and for this discussion SPRING... isn't this going to inject possible rust factoring on the non stainless components?
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- otakar
21 Feb 2010 06:56 - 21 Feb 2010 06:59
Old Man Rock wrote:
+1 since the valves were not removed I definitely see a problem once the water gets into the valve springs, Iron valve guides and all those steel parts in that area. I hope that it is planed to remove all those components to clean out all that moisture. And since that now has to be done regardless, why not have done that first so you could remove all the crud that builds up on top of the valves? I am not disputing the rather ingenious idea of using the steam source, I am disputing however doing it to a head in the state of assembly it is in!?!?!?
:ohmy: Corrosion has just been introduced into areas where it should never had been. I used a pressure washer on my head and it worked beautifully at the 1600Psi of pressure, but my head was totally disassembled.
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
Last edit: 21 Feb 2010 06:59 by otakar.
- guitargeek
21 Feb 2010 13:30
Yes, of course I removed the valves after this step, then scrubbed the head some more with SOS pads, then (gently) chucked my valves in the drill press and cleaned them up.
I soaked all the valve springs, retainers, and split keepers in hot, soapy water, rinsed them thoroughly, then stored them in a plastic Folger's can, saturated with WD40.
Then came the port & polish:
The whole story is here: Freshening Up .
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- guitargeek
29 Nov 2012 03:11 - 29 Nov 2012 03:15
While I got okay results from the steam blaster, I've since gotten into soda blasting.
For smaller stuff like fasteners, I got a vibratory tumbler.
Last edit: 29 Nov 2012 03:15 by guitargeek.
