- Thank you received: 2
found stripped cam holder bolts
- Galactica
77KZ1000
76 KZ900
- scubarod
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Mcdroid
- Gone Kwackers
- Thank you received: 317
As a matter of reference - - -
KHI FSM Mar. 12, 1979 [Part No. 99931-540-03] covering '77~'79 KZ1000 specifies
95~113 in-lbs.
KHI FSM KZ900 Mar. 28, 1977 [Part No. illegible ] covering '73Z1~'76KZ900 specifies
104 in-lbs.
Chilton's Kawasaki 900Z1 Repair and Tune-up Guide 1973-1974, 1974 First Edition covering '73-'74Z1, specifies
105 inch pounds.
12 ft-lbs is 144 in-lbs, and obviously too tight by almost 50% over-torqued, at least for the large Kawasaki fours through 1979 models.
Am wondering exactly which manuals contain the bogus information?
Apparently all KHI manuals for 'J' motors. This would be the KHI manuals for the KZ1000K,M,R, and J and the KZ1100B series. By extension, also the ZX1100A series and the KZ1100R1 (since the base manual for the these bikes is the KZ1000/1100 manual). Additionally, the shaft-series KZ1100A,D, and L also all have recommended torques of 12 ftlbs (= 144 inchlbs). I suspect this also applies to P models as they use the 1000/1100 manual as the base manual (but I have have never thumbed through a P supplement to see if it was emended).
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- TeK9iNe
- What did you do!?!
- Thank you received: 28
I'm not a mechanic and don't know what a parkerized bolt even means, but the bolt is not the problem, it's the aluminum in the head that strips, particularly the exhaust side. I don't know if it's the heat from the exhaust or just material is weaker on that side of the head, but they will strip at 7 ft/lb. Oops don't do ft/lb. They will strip at 84 in/lb the same exact way:) . It's not like the cam caps ever vibrate loose, so why in the world risk stripping? Torque to 60-65 in/lb.
Good point.
I've never stripped anything at 90 in/lbs, but I have stripped an oil pan bolt or two at 95.
Just never in the heads I've done.
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- larrycavan
- Visitor
The problem isn't the bolt nor the head. The problem is the guy with the bolt and the wrench in his hand that caused the threads to strip.
There's the bolt and the hole. The bolt cannot put itself in to the hole, it requires human intervention....
Along comes the human....screws the whole process up Then seeks to put the blame on the bolt and or the factory service manual..... :silly:
What sucks is you never know which human was in there messing with the bolts before you got there.:laugh:
- larrycavan
- Visitor
The 4 bolt cap design has problems.
- Mcdroid
- Gone Kwackers
The FSM specs are not wrong. There are 2 different torque specs for the 2 different bolt types. Both work just fine for their associated design if you know what you're doing.
Hmmm...but you admitted to not following the Kawasaki specs of 12 ftlbs and using less torque.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- 9am53
- homebrew, and some bbq
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290335959914
'84 GPz900r
'71 CB350
s289.photobucket.com/albums/ll231/9am53/
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
As for tapping the hole with the head still on the bike, the method I uses is to cover the open head with a sheet of aluminum foil. Then I press down over the hole area until I find the impression of where the hole is. I then smear a good glob of grease around that spot, then drill the hole. The grease catches the shavings, and the rest of the head is covered and protected by the foil sheet.
West Linn, OR
- larrycavan
- Visitor
Kawasaki FSM's for new models would arrive and then some later point in time, corrections to misprints would arrive. So yes, there are incorrect specs in service manuals, even from the factory.
However, the cam tower bolt specs were correct for the KZ and J motor cam towers.
- nads.com
- Thank you received: 20
mine vibrated loose and spun some bearings racing an RC-51. I rode it for 25 miles with smoke out the left pipe. I use loctite at the top threads now too. Just get some harder bolts and the certs and close the book on cam bolt problems. Don't even think about tapping out yet!I'm not a mechanic and don't know what a parkerized bolt even means, but the bolt is not the problem, it's the aluminum in the head that strips, particularly the exhaust side. I don't know if it's the heat from the exhaust or just material is weaker on that side of the head, but they will strip at 7 ft/lb. Oops don't do ft/lb. They will strip at 84 in/lb the same exact way:) . It's not like the cam caps ever vibrate loose, so why in the world risk stripping? Torque to 60-65 in/lb.
