- Thank you received: 2
found stripped cam holder bolts
- KYKZ1100
I got the basic 6mm Time Sert at Fastenal for $60.67. I see it on ebay now with a BIN of 59.99 with free shipping.
1981 KZ1100A1 Shaft
2007 BMW R1200R
- jeffasaki
- Thank you received: 44
79 and later 12 ft lbs
73 to 78 chrome bolts 9 ft lbs
Parkerizied (dark bolts) 7 ft lbs
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- scubarod
- scubarod
- KYKZ1100
1981 KZ1100A1 Shaft
2007 BMW R1200R
- Buda
Am wondering exactly which manuals contain the bogus information?
Good Luck! [/quote]
My 81 KZ1000-1100 FSM says 12 foot pounds on the cam cap bolts, I striped a couple my self last winter.
1982 KZ 1170 LTD
10.25 to 1 comp
K&N pods
GPZ cams
Vance&Hines pipe with comp baffle
dyna coils and wires
97 Valkyrie Standard
- scubarod
- scubarod
- KYKZ1100
1981 KZ1100A1 Shaft
2007 BMW R1200R
- larrycavan
- Visitor
If the bolts are chrome, go with 8 ft/lbs of torque.
If the bols are black [parkerized]go with 11 ft/lbs.
They started with the blak bolts in 1979 and continued on through the remainder of the KZ and the J series with that type.
Helicoils suck. Time Certs or retap to 1/4-28 SAE.
Be careful. I've seen guys get taps in there and bulge out the tappet bores. Then the bucket won't go down it. It's not that common but IT CAN HAPPEN.
- TeK9iNe
- What did you do!?!
- Thank you received: 28
scubarod wrote:
thanks i will look into it. but really angers me now that i probably stripped out 1 myself because of 12ft lbs in my book....
As a matter of reference - - -
KHI FSM Mar. 12, 1979 [Part No. 99931-540-03] covering '77~'79 KZ1000 specifies
95~113 in-lbs.
KHI FSM KZ900 Mar. 28, 1977 [Part No. illegible ] covering '73Z1~'76KZ900 specifies
104 in-lbs.
Chilton's Kawasaki 900Z1 Repair and Tune-up Guide 1973-1974, 1974 First Edition covering '73-'74Z1, specifies
105 inch pounds.
12 ft-lbs is 144 in-lbs, and obviously too tight by almost 50% over-torqued, at least for the large Kawasaki fours through 1979 models.
Good Luck!
Absolutely.
I say 95 inch/pounds MAX, and use a small bead of red threadlocker on just a couple of threads near the top.
Werks perfect
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
- RonKZ650
- Thank you received: 240
