- Thank you received: 104
What kind of exhaust is this?
- PLUMMEN
- saxjonz
- KawboyZ
- Thank you received: 76
79 LTD B3
- Old Man Rock
- Thank you received: 225
Damn, will that thing hold his Toyota baffle? :S
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- hocbj23
- Visitor
- hocbj23
- Visitor
- Jack
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
- tybolt99
- From where KZs came
- Thank you received: 3
Good Lord what a thread.Nobody can answer what the original question is so we all take off in 9k directions. Whoa.So if anybody wants a real woody, I have a set of VHA drag spigots, springs and spring tool for sale.Hook up those pipes and these spigots and y have -who the H--- knows but it will go like stink and sound great doin it.Lol.bj
Still wondering what this is. I found number "2110". Is this help any anyone?
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
- Thank you received: 2098
I have that exact same one in chrome. With that adjustable rear mount. It is a Bassani.
otakar wrote:
That is the competition Basani.
otakar wrote:
Hay Guys, I just posted a Street Bassani in the classifieds. This is the one that you can retain the centerstand and get to the filter. This is not the race pipe like in the previous picture.
- tybolt99
otakar wrote:That is the competition Basani.
otakar wrote:Hay Guys, I just posted a Street Bassani in the classifieds. This is the one that you can retain the centerstand and get to the filter. This is not the race pipe like in the previous picture.
Oops. Now I see the hanger. :woohoo: When I saw otakar's post somehow I was thinking that got hanger like Kerker.:blush:
Thanks Patton and otakar.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- Splandman
Current Bikes
1980 KZ1000E
- Old Man Rock
Measure the header riser lengths into the collector on both exhausts you have. You'll most likely find the new riser lengths ~ 3" longer thus tuned for lower rpm range.
And yes, there's other factors involved throughout the exhaust design that steer/tune for desired results.
During my research, found this and comes out correctly in exhaust pipe calculators....
A reduction in primary pipe Diameter of 1/8 of an inch will move the torque peak down by 650-800 RPM.
Conversely an increase in diameter of the header will raise the engine speed at which max torque occurs by approx the same RPM for each 1/8 of increase.
Adding length to the primary pipe will increase low speed and mid-range power, with corresponding reduction in power at max RPM.
Shorter primaries give an increase in high speed power, at the expense of reduction in the mid range. However, there will be little change in peak torque or the engine speed at which it occurs.
To establish the best length of primaries for your specific engine, you will need to know the exhaust valve timing, and the revs at peak torque. The bike’s manual or owner's handbook should provide these two figures.
This formula will then approximate your requirements:
Note: The primaries are measured from the head of the exhaust valve and not the flange seat on the outside of the exhaust port. This is because different head designs have different lengths of ports.
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
