- Thank you received: 3
What kind of exhaust is this?
- tybolt99
- From where KZs came
These came with 75 Z1. End of pipe is about 3 1/2".
82 KZ750 H3
76 KZ900 A4
74 Z1A
73 Z1 (on the shelf)
84 ZN1300
Franklinton, NC
- Grantl
- KZRider is Da Bomb!!!
- Thank you received: 4
1981 KZ1000 CSR
1983 KZ750 Project Bike
1990 550 Zephyr
1994 KZ1000 P
- jeffasaki
- Thank you received: 44
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- tybolt99
I want to find baffle that is 3" OD to fit in this. Looked at Bassani, but nothing this size was there.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- TerryK
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- chance
- Life long biker/
- tybolt99
Chance,
No, nothing is on the other side. The only hole is the one you can in the third picture, the hole for baffle cap.
It is not super heavy but it is not feather light.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- chance
- Life long biker/
- roy-b-boy-b
- Thank you received: 103
- tybolt99
I mean 3 1/2".Kerker I got is 3 3/4" cap OD.2 for Kerker. Old Kerker had 3"ID?
I look all way around and didn't see no name or number stamped.I will check collector bottom again.
82 KZ750 H3
76 KZ900 A4
74 Z1A
84 ZN1300
Franklinton, NC
- loudhvx
- Thank you received: 1616
I put in another vote for Mac. Those flanges at the head look like the Mac type. The Kerkers i've seen use the removable flanges with the 2-piece collars.Must be an old kerker But I smell Mac.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
