- Thank you received: 225
ground clearance under exhaust collector
- Old Man Rock
13 Dec 2009 17:51 - 13 Dec 2009 17:53 #338846
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Replied by Old Man Rock on topic ground clearance under exhaust collector
Here's some profile shots of the Kerker installed in my setup...
Maybe will help in providing some insight on the exhaust angles, widths from rear & front perspectives...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 13 Dec 2009 17:53 by Old Man Rock.
- Ktm181
- Man made it, so Man can fix it
- Thank you received: 1
13 Dec 2009 21:42 #338870
by Ktm181
Replied by Ktm181 on topic ground clearance under exhaust collector
Thanks for the superb photos OMR, nice bike. Would i be able to trouble you for a couple of measurements when you have some time? Say, outside diameter of header pipes where they pass under the LEFT frame rail and how much clearance to the frame rail & the outside diameter of the pipe as it passes under the right side frame rail and its clearance to the frame?
thanks heaps,
Kt
thanks heaps,
Kt
- Old Man Rock
14 Dec 2009 02:28 #338885
by Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
I'll take some more photo's of the areas your requiring measurements for. I'll take measurements from outside header tubing to frame left & right side and supply today/tomorrow...
OMR
OMR
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
