ground clearance under exhaust collector
  • Ktm181
  • Topic Author
  • Man made it, so Man can fix it
09 Dec 2009 18:13 #338301 by Ktm181
Hello guys,
have a Japanese 4 into 1 system with collector directly under right side foot peg (you can get a look at it on my profile,just), collector hits ground when leaning over to right side,cant be easily modified. What do you guys find in the way of your exhausts for ground clearance? I am looking at a Kerker but want to retain oil filter access and centre stand, what do you recommend???
Cheers & Merry Christmas
Kt
Emu Plains,
Australia.
09 Dec 2009 20:42 - 09 Dec 2009 20:45 #338332 by TerryK
Replied by TerryK on topic ground clearance under exhaust collector
That looks a sidewinder exhaust. It's made for drag racing and not cornering. Go with the Kerker, you'll love it! I don't know of a performance exhaust that you can retain the center stand.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
Last edit: 09 Dec 2009 20:45 by TerryK.
10 Dec 2009 03:14 - 10 Dec 2009 03:14 #338354 by roy-b-boy-b
Replied by roy-b-boy-b on topic ground clearance under exhaust collector
This is a Sidewinder and there are clearance issues.
The pipe you have seems to have as much room as my V+H header.
I like my bikes low and run shorter suspension.
Are you running stock shocks? Roy
Last edit: 10 Dec 2009 03:14 by roy-b-boy-b.
10 Dec 2009 06:21 #338368 by Old Man Rock
Replied by Old Man Rock on topic ground clearance under exhaust collector
The Kerker allows for oil and filter drain/removals... ;)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
10 Dec 2009 06:30 #338370 by Patton
Replied by Patton on topic ground clearance under exhaust collector
Yes, and fwiw, easier that V&H.
Good Luck! :)
10 Dec 2009 06:36 - 10 Dec 2009 06:54 #338372 by Patton
Depending on the particular 4>1 exhaust system involved, am thinking a center-stand "stop" when retracted may be fabricated. ;)
But some folks are put off by the look of a retracted center-stand sticking out the left side like some kind of mutated appendage. :laugh:
Good Luck! :)
Last edit: 10 Dec 2009 06:54 by Patton.
10 Dec 2009 08:18 #338380 by kzr750r1
Replied by kzr750r1 on topic ground clearance under exhaust collector
Now for the kz750 the oil maintenance access for my Kerker is not retained. To change oil or filter I have to remove the entire unit. In my quest for a 4-2-1 years back there was one company(Remus)offering a zephyr kit that was an option to start as a base. I would have had to modify it for the Gpz frame and canister of choice.
I'm kind of surprised OMR said the access is retained.
Nice looking bike BTW.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
10 Dec 2009 08:23 #338381 by Old Man Rock
Was speaking in regards to the 900/1000 series..
I didn't see his specs nor your 750 so my bad...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
10 Dec 2009 08:52 #338382 by kzr750r1
No fault here... Just supise your able on any 4-1 that slings under the bike. Even on my sig picture you can see the collector.
Were talking about a KZ900 correct?
My collector rests just under the filter access and the oil plug is blocked (from full removal) by the #1 header pipe.
PIMA BTW. My best option is building a pipe from scratch, but as many things this is low on the priority list.
10 Dec 2009 10:56 #338394 by Old Man Rock
On my KZ900 with the Kerker Megaphone series... I can remove the oil filter without having to remove nor loosen the exhaust system...:cheer:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
10 Dec 2009 11:12 #338397 by keith1
Replied by keith1 on topic ground clearance under exhaust collector
same for my v/h.....
  • Ktm181
  • Topic Author
10 Dec 2009 16:08 #338439 by Ktm181
Replied by Ktm181 on topic ground clearance under exhaust collector
Hi Roy,
YES, standard length Ikons, might have to try and find something longer to lift it up a bit. I do a few trips on him so need to keep the centre stand for access to remove wheels etc for punctures etc OR modify this exhaust!
kt
