- Thank you received: 1
ground clearance under exhaust collector
- Ktm181
- Man made it, so Man can fix it
will the Kerker allow retention of centre stand? I know it allows filter access.
Kt
- roy-b-boy-b
- Thank you received: 103
- larrycavan
- Visitor
Depending on the particular 4>1 exhaust system involved, am thinking a center-stand "stop" when retracted may be fabricated.
But some folks are put off by the look of a retracted center-stand sticking out the left side like some kind of mutated appendage. :laugh:
Good Luck!
I was severely "PUT OFF" by one.......I'm talking big time high side...air born....heluva crash type of "put off" one time on a GS1100.. :ohmy:
- TerryK
- Thank you received: 3
thanks Terry,
Kt
On the 900/1000.I don't think so, although I've never tried because I don't use the center stand.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- kzr750r1
- Thank you received: 9
BSM looks to have a bunch of options.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- Gman
- Thank you received: 5
1978 KZ1000
1965 Harly Electra Glide
2002 Gold Wing
1974 Z1 900 project
- Gman
1978 KZ1000
2002 Gold Wing
1974 Z1 900 project
- trianglelaguna
- Thank you received: 235
1976 KZ900
2003 ZX12R
2007 FZ1000
2004 ninja 250R for wife
- krazinite2003
With both oil maintenance and center stand being a requirement your driving into custom land or going back to OEM style. Check Klasmo or other online distributors for ideas. These and other options are out there...This found for 1100 ST and other KZ 900 1100 range.
those pipes are what i am looking for can you tell me the web site is please or do they make them for the 83 kz750 L3
i have two 1983 kz750 L3
- Ktm181
Gman & Trianglelaguna, what SUPERB examples of "golden oldies". Mine is clean and orignal except for the paint work.
Looks like more shopping in the future. I am just waiting at the moment on a "new" Larry Cavanaugh head and some smooth bores from Z1E which have killed my shopping budget for a while now!
Merry Christmas to all,
Kt
- Old Man Rock
- Thank you received: 225
Regarding my conversion 17" rims compared to the OEM 19/18" rims, I lost a couple inches of ground clearance.
I have the Michelon Road Pilot 2 tires...
With the Kerker installed, I have ~ 4"-5" clearance directly underneath (pending the exhaust tubing location) you measure from)...
Not much clearance so for speed bumps and such, hit it at angles or avoid as much as possible... In the phoenix area, most speed bumps have a cut away in the divider striping, so I ride in between at this point avoiding the bump....
OMR
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Ktm181
Cheers,
Kt.
