- Thank you received: 1
ground clearance under exhaust collector
- Ktm181
- Man made it, so Man can fix it
have a Japanese 4 into 1 system with collector directly under right side foot peg (you can get a look at it on my profile,just), collector hits ground when leaning over to right side,cant be easily modified. What do you guys find in the way of your exhausts for ground clearance? I am looking at a Kerker but want to retain oil filter access and centre stand, what do you recommend???
Cheers & Merry Christmas
Kt
Emu Plains,
Australia.
- TerryK
- Thank you received: 3
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
- roy-b-boy-b
- Thank you received: 103
The pipe you have seems to have as much room as my V+H header.
I like my bikes low and run shorter suspension.
Are you running stock shocks? Roy
- Old Man Rock
- Thank you received: 225
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
- Thank you received: 2098
The Kerker allows for oil and filter drain/removals...
Yes, and fwiw, easier that V&H.
Good Luck!
But some folks are put off by the look of a retracted center-stand sticking out the left side like some kind of mutated appendage. :laugh:
Good Luck!
- kzr750r1
- Thank you received: 9
I'm kind of surprised OMR said the access is retained.
Nice looking bike BTW.
KZ750R1 + 1991 ZR750 = KZR750R1
Better to be shot out of a cannon then squeezed through a tube. - HST
- Old Man Rock
I didn't see his specs nor your 750 so my bad...
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- kzr750r1
Were talking about a KZ900 correct?
My collector rests just under the filter access and the oil plug is blocked (from full removal) by the #1 header pipe.
PIMA BTW. My best option is building a pipe from scratch, but as many things this is low on the priority list.
- Old Man Rock
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- keith1
On my KZ900 with the Kerker Megaphone series... I can remove the oil filter without having to remove nor loosen the exhaust system...
same for my v/h.....
- Ktm181
This is a Sidewinder and there are clearance issues.
Hi Roy,
YES, standard length Ikons, might have to try and find something longer to lift it up a bit. I do a few trips on him so need to keep the centre stand for access to remove wheels etc for punctures etc OR modify this exhaust!
kt
